HP Compaq Business Desktop d330
Problem for HP Compaq Business Desktop d330
Hello'I' gt a compaq d330 ut desktop Pc to arrange
By doczya on Nov 08, 2009
Hello,i'v got a compaq d330 ut desktop Pc to arrange for free to a needed student with the promess to format all/ however, as i don't have the origunal cd's of this machine ' i tryed to install 3 dirfferent legale copy of win xp and the process is stop in the middle with an error popup for all of them, i think the bios of this "Hp invent" is set to block any win os that not come from HP factory. need help , plz
ps. sorry for my English
Comments:
Nov 08, 2009
- thank you for your prompt answer ' but the win xp setup format , with my autirity , to ntfs and stop instlation anyway.
Nov 10, 2009
- Hello friends and thank you for trying help me, as I'm new on this forum, I'd some difficult to se how it function and I'm sorry if you feel it:-(, in meantime to try to fix my problem, I'm running just now the same hard drive (IDE) on another pc to see if it the origin of my problem. when I'll finish to do it and if it'll work I'll try to move it as is to the HP PC and I'll report here the results
Nov 13, 2009
- Thank you Raf. as i' have wrote at the last post, i' tried to mount the system on a other PC and now it work fine with all update. how ever it still possible that the d330 have some hrdware issue car i'v got dfew blue screen befor and had difficult to install some free anti virus' Nod32 is workung well on this machin
Solution #1
posted on Nov 08, 2009
Not Helpful)
greg_margo
Rank: Guru  HP Computer Hardware  Expert
Rating: 91%, 695 votes
If you format the hard drive NTFS format you should be able to install Windows XP. If the computer is old, the hardware may not work with Windows XP. Any computer built in last 8-9 years should work with Windows XP.
Comments:
Nov 10, 2009
- If your version of Windows XP is old, it may not have the necessary drivers to support the hardware on your machine. It's not a matter of being legal, it's simply a matter of having the drivers. Another thing you should try is enter the BIOS (Press F10 on startup) and run the Hard Drive Self-Test. You may have a bad hard drive. If that's the case you won't be able to install any Operating System. As far as your rating of my answer goes, there was nothing inappropriate about my answer. You may not agree with answers here on Fixya but given the limited information you provided, (you didn't say exactly what the error popup you got) any answer you get is merely an educated guess.
Was this helpful?
Yes
No
Solution #2
posted on Nov 09, 2009
Not Rated)
dupalopez
Rank: Guru  Computer Hardware  Expert
Rating: 94%, 18 votes
You're not saying what sort of error you're getting?
BIOS on d330 does not have any limits on whichever operating system user wants to install. I've had d330 running various operating systems with no issues. Your d330 might be some hardware problem however. First things I would try would be checking the hard drive and memory.
Good luck,
Raf
Comments:
Nov 13, 2009
- What error are you getting? This would be the most helpful piece of information we need.
Was this helpful?
Yes
No
Solution #3
Not Rated)
spentza_will
Rank: Wiz  Computer Hardware  Expert
Rating: 82%, 11 votes
Hi Dear,
As observed form your issue. There might be multiple possibilities for your problem.
Is your Hard Drive a SATA hard drive?
If yes then ordinary windows XP cd is of no uses. This is because windows XP does not recognize a SATA drive.
While installing the OS, it will stop in between and give you compatibality error.
If you are getting the same error then, you should try to install form a windows xp OS which is built for installing on SATA hard drives. Or you must try to upgrade your Bios settings. This will help you out.
If you need more help do come write to me.
Have a nice day.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Business Desktop
Questions and Unsolved Problems for HP Compaq Business Desktop
Do you recommend HP Compaq Business Desktop d330?
Answer
Answer
My monitor won't come on. Its new and works with other e4000. I made sure all connections were in... (More)
Answer
is the acer as5517 series laptop using a pci express card for the internal wireeless card
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
My Imation flash drive does not recognize the password. How can I read it ?
Answer
I have an HP Compaq d330. Yesterday it worked but today the "on" button only produces red... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq Business Desktop...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
