Question about Palm TX Handheld
Palm tx the bottom bar (were the bluethooth, alerts, find, etc) are does not respond with the stylus
  • 59 Answers
This has some suggestions for the TX digitizer issues
Posted on Jan 07, 2008
Need instructions on a hard reset
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
Hi! I bought a referbished TX from you in January of 2009 (I think). It has been working great. However, the other day when I turned it on, the digitizer wouldn't work. Buttons work, everything else...
Disclaimer: I'm just a tech answering you request. I don't know who sold you the TX.
Have you tried to reset the TX?
First, save your data:
then reset:
While holding the Power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the RESET button inside the hole on the back of your device.
The RESET button may be somewhere else on the back of your particular device.
First you'll see a palmOne or Palm logo and a progress bar. Keep holding Power.
Then you'll see a grey circular Palm PowereWhen the warning appears, press Up to confirm the hard reset.
If a language selection screen appears, select the same language you selected for your desktop softwared logo. Now you can release Power.
Then sync it to you PC.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2010 | Palm TX Handheld
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Touch screen not precise/not working properly
ttry calabraiting the screen that may help a little i think it will be under pref
Mar 26, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
Touchscreen doesn't respond
Your digitizer has whacked. Has this been solved
Dec 31, 2008 | Palm Z22 Handheld
I had a similar same problem. It occured when pluging or unpluging in the USB cable into the bottom of the Palm TX when the other end of the cable was already pluged into a live USB port on my PC.
The solution was to make sure the cable is unpluged first from your PC before you plug or unplug the cable into the bottom of your Palm TX.
Sep 09, 2008 | Palm TX Handheld
Palm TX is dead
give it aq reset its in the back there is a mall hole puch it with the stylet
rate me !!!
Aug 16, 2008 | Palm TX Handheld
Palm tx. Unfreeze? New. 2 months. Not much on. No added programs, games etc.
What happens when you press the reset button on the back of the TX?
May 27, 2008 | Palm TX Handheld
Palm TX
do you have a screen protector? if so, i suggest checking to see if there is anything caught between it and the screen. there might be a speck of dirt or whatever that is causing that. also check for dirt accumulating around the edges.. hope that helps. good luck
Jun 06, 2007 | Palm TX Handheld
Palm TX Handheld Logo
126 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
