Most likely you need to remove burner caps and clean out holes. While it is off turn it on for a sec and see if you small gas. CAREFUL just a sec.
A good cleaning is best before you call your gas company. Our's PG&E do'es it for free check with yours before you call a repairman.
I just cleaned the inside glass on my maytag "gemini" and you take the inside door panel off, thencarefully lift out the glass and clean it.then reassemble. I found it easier to remove the door and lay it on thekitchen table with a blanket under it. Hope yours is similar as I suspect it is. Good luck and keep smiling. Please rate me...Thanks
