Espressione Caf? Retro Cappuccino/Espresso Maker - Silver Logo
Posted on Nov 08, 2009
Where do I find a new portafilter for this model?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 17, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
504
Points
Where do I find a new portafilter for a Espressione Cafe' Retro' machind
3helpful
My portafilter is leaking during brewing. seems it can not get as tight as it previously was able too. I have the model with the 3 settings and even on Ristretto, the coffee comes out way too fast and the...
You need a new brew head gasket. They are not that hard to change. Four nuts hold the chrome head on. Once the chrome head is removed the gasket is pulled off then the brew head is cleaned and then you can put the new gasket on. Check ebay.
3helpful
The handle is coming apart. It does not fit tight enough & sometimes falls while the coffee is brewing. Where can I purchase a new one to fit my Solis SL 70 machine purchased late in 2004.
HI
If the portafilter is coming out when brewing your brew head gasket needs to be replaced. If you have never replaced your brew head gasket its way beyond time. They should last about 3-4 years at the most. With a good brew head gasket the portafilter should be easy to lock in, not requireing a lot of pressure to force it over. Try replaceing the gasket first before you invest in a new portafilter. If you really need one I have some and the gaskets.
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Coffee does not flow into shot glasses. water and coffe grounds seap and sprew from around the top ad down the sides
I had a brand new Via Venezia that I could barely get to make espesso, nothing or very little came out. Got a new portafilter and now it work beautifully, espesso flies out of the thing wonderfully. Bad news is a new portafilter is like $65. I can't believe they are shipping these with bad portafilters, but they are.
Broken portafilter!
5helpful
2answers
No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
I have cleaned the machine, taken apart the filter and even attempted to run white vinegar through it to remove any potential deposits. I still can't get water through. Any suggestions?
You may need a new portafilter. I got a brand new Via Venezia and it never worked right out of the box. I got a new portafilter and now the espesso flies out of the machine. Bad news is the portafilter is like $65. They say you are not supposed to take those portafilters apart, they have some weird pressurized part that gets wrecked if you disassemble them.
1helpful
Replacing orange gasket in top or portafilter
here is a picf920683.png of the portafilter for the saeco
Top Espressione Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
Gary F
Gary F
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
