HP vp17 Monitor
Problem for HP vp17 Monitor
After shut down some kind of (zupp) sound comes
By amit_moonlig on Nov 08, 2009
after shut down some kind of (zupp) sound comes from the moniter, it comes after i switch off the UPS, it may be some charge present after shut down, which Leads the LCD to on after while, will this sound going to make any problem
Solution #1
posted on Nov 08, 2009
Not Rated)
swDemonDog
Rank: Guru
Rating: 87%, 24 votes
Capacitors hold a charge for a short time.
This may be the sound you are hearing.
Even with out the UPS the Monitor will probably make the same sound when turned off. Unless it is getting louder, it is nothing to worry about.
Just be sure you turn the monitor off BEFORE the UPS. :)
Was this helpful?
Yes
No
Popular Solutions for HP vp17 Monitor
Questions and Unsolved Problems for HP vp17 Monitor
Do you recommend HP vp17 Monitor?
Answer
Answer
I have a 2007 47" viewsonic that is deciding on it's own to show in letter box, wide screen ,... (More)
Answer
Monitor will not go out of sleep mode on original CPU. Hooked up to different CPU it is fine.
Answer
My HP VP17 monitor has no sound. I have reloaded the driver with no luck. Any ideas?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP vp17 Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
