Question about Akai PT46DL10 46" HDTV-Ready Television
Akai 46in rear projection
The lamp light turned on and after a few days, the color faded and finally the screen just sent blank, i still have audio, just no picture. I've ordered a lamp from deadlamp.com and can't even get a tracking number out of them a week and a half later, let alone an email back.
Is my lamp gone or is there a bigger problem?
  • wilk32 Mar 09, 2008
    Where can i order a lamp for the PT46DL1046 I need th e one that ennds with the letter J .
    Problem Solver:
  • 15 Answers
  • 579 Answers
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Hope ya fix it!
Posted on Jan 06, 2008
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
We have the Akai 52"
Replace the lamp, after you replace the lamp reset the lamp hour meter good day and best regards.
Aug 28, 2011 | Akai PT5492S 54" Rear Projection...
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
My Sony kp-53xbr35 Rear Projection TV screen turns green for a few seconds when I turn it on, then goes blank. Audio still works. Timer/Stand-by blinks until screen goes green, then stops, even when screen...
check the lamp out if the lamp go to this website http://www.discount-merchant.com or if the lamp is not the issue maybe can be the board in the same page you can find the parts that you maybe would nedd
regards
Dec 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Lamp red light is on when tv is on and not flashing tv info says solid light is lamp life expired but tv is working fine is this a problem.
It's only a problem when you try and finance a new bulb ($400.00 for mine). But seriously, the only "problem" is that an older bulb exhibits much lower light levels and the picture has crappy color, brightness and contrast. Keep a coffe can around and put a few bucks in it everytime you watch it. when the bulb finally blows you'll have a couple hundred bucks in there towards a new one. (a little easier to handle)
Packman
Sep 08, 2009 | Akai PT4298HD Rear Projection Television
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Hitachi model cu4601b/k
I had this problem in a 46UX50B (I think that's the model), and it turned out to be some capacitors in the power circuit(?). After the service guy replaced those, it hasn't failed to come on since.
Apr 11, 2007 | Hitachi 46UX50B 46" Rear Projection...
Akai hdtv 1080i, No Sound
I sounds like a bad filter in the sudio supply circuit finally took out the sound output chip or the power supply that controls the sound circuit. its a soliud state set and there are no user replaceable parts inside this set. Unless you have had solid state repair experience, please be safe and call in a pro to assost you in this repair. good Luck ps Please rate this thread
Oct 19, 2006 | Akai PTH5498 54" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
170 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
