Lexmark X6170 All-In-One InkJet Printer
Problem for Lexmark X6170 All-In-One InkJet Printer
Fax rings but machine doesn't answer
By diane_gainey on Nov 08, 2009
fax rings but machine doesn't answer
Solution #1
posted on Nov 08, 2009
Not Rated)
swDemonDog
Rank: Guru
Rating: 87%, 24 votes
First check the setup/configuration and make sure the Fax is set to answer on 1 or 5 rings. If the line is dedicated to fax then it can be set to answer after the first ring. Fax machine works off a modem that listens for the ring and handshake tones. If the machine has been hit with a lightening spike then the hearing portion may be dead.
Translation: Your fax machine is Deaf and can not hear the ring.
It will never answer and do the fax handshake required.
If it is a new machine and still under warranty. Take it back as soon as you can.
If this is a fax machine installed at work.
Be careful, some phone systems used in the corporate buildings have too high a voltage and will fry the modem/fax card.
If this is a home machine with DSL.
Make sure the DSL line filter is applied correctly.
It will be clearly marked Phone or DSL line. Do NOT connect the phone/fax line into the DSL line connection.
Hope this helps!
Was this helpful?
Yes
No
Popular Solutions for Lexmark X6170 All-In-One
Questions and Unsolved Problems for Lexmark X6170 All-In-One
Do you recommend Lexmark X6170 All-In-One InkJet Printer?
Answer
Answer
mESSAGE: pRESS POWER & THEN CLEAR PAPER JAM- tHERE IS NO PAPER JAM-wILL not PRINT
Answer
shared x6170 on XP desktop and trying to print to it from wireless vista laptop. loaded vista driver... (More)
Answer
When I refill my lexmark 44xl cartridge the printer says there is no ink in the cartridge after it... (More)
Answer
I have lexmark All in one Model X6170 keeps giving Paper jam message and suggest to press select but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lexmark X6170 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
