Question about Panasonic SC-HT680 System
Remote/Remote sensor My DVd player does not pick up my remotes signal I changed the batteries the lights light up on it but the dvd does not respond to it.
    Genius:
  • 1,067 Answers
Bad remote maby kids dropped it best bet buy new one
Posted on Jan 06, 2008
6ya staff
SOURCE:
Dvd highlander has stopped responding to remote , used twice before no problem , batteries are new , and lil light in remote is sending ?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jan 08, 2015 | Televison & Video
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
SONY DVD REMOYTE RMT-187P NOT RESPONDING EVEN AFTER CHANGING THE BATTERY
The remote might be bad or the sensor on the remote or the television is bad. If the metal that holds the sensor light on the remote or the television becomes rusty and breaks off, the remote will not be able to operate the television anymore.
Check the remote and the televisions remote sensor if it is still okay. If they are both okay, then it means the remote is dead and need to be replaced.
Thank you for using fixya.
Caseytech
Sep 05, 2011 | Televison & Video
My dvd player is not responding to my remote RMT-D187A the dvd player is fine and will play dvd's but the it's not responding to the remote-I've changed the batteries....there is no way to...
To make sure the remote works or not. See if it blinks if you shoot the pointy end to a mobile phone in camera mode. If it's working fine there, some other issue. At least you know if it's a battery thing.
May 08, 2011 | Sony Televison & Video
Remote control not "talking" to system. Can't finalize DVD because it won't respond. Tried new batteries...any ideas?
try to check battery terminal that connect the main board of your remote if well contact try to check the led sensor to check the sensor use a camera or your cellphone if had a camera point the sensor in the lens of your camera then press any button you will see a red light that glows if you are not seeing a red light replace the sensor its defective thank you.
Oct 15, 2010 | Sony RDR-VX525 DVD Recorder/VCR
The remote for my Panasonic HT520 doesn't respond. When the CD-DVD button on the remote is pressed the lights come on on the remote, but still nothing from the player. The player works fine on it's own,...
Ok let me verify; you have an HT-520 home theatre with integrated DVD player. When you press the DVD input you can't control certain aspects of the DVD player or the DVD player does not respond at all?
Does the DVD respond at all if you put the remote into another mode (should be called Amp or Receiver)? Can your remote be programmed for different devices and mabe it was programmed to control a different DVD player?
I will search the unit in my knowledge base and let you know some exact steps to try. If you could clarify some of thoes details that would be wonderful.
Thanks,
Kevin
Jan 24, 2010 | Televison & Video
I have the Sony dvd changer that holds 400 dvd's and the remote was working fine one day then just stopped the next. I've changed the batteries and the light turns on but the player just doesn't respond
to test remote shine it into camera ( turn on camera ) press button you should see light flashing if not open remote and clean circuit board and battery contacts
Dec 04, 2009 | Sony Televison & Video
DVD recorder DMR EZ27EB
The remote control code is wrong. Change to the correct code. The batteries are depleted. Replace them with new ones. Point the remote control at the remote control sensor on the main unit. Remove obstacles between the remote ccontrol and the main unit. Remove dust from the transmission window and the unit's sensor. Colored glass may obstruct the signal reception/transmission. Don't place the signal sensor in direct sunlight or in areas that be subject to sun exposure. It may be necessary to set the code on the remote control again after changing the batteries. It may be necessary to set the manufacture code again after changing the batteries.
I hope this info can be of some help to you. Ms Tanya 2/12/08 4:02AM CST.
Jan 29, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Coby 626 DVD Player Remote Not Working
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Mar 18, 2007 | Coby DVD-224 DVD Player
MY DMR-EH55 has problems repsonding to the supplied remote control
Firstly, check you do not have bright light shining across the IR sensor.This can degrade the signal to noise ratio of the IR receiver.
Second, check you do not have a noisy mains electricity supply, arcing plug block or running from square wave inverter supply. Either of these can cause problems with IR receiver in the DVD player.
Feb 25, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic SC-HT680 System Logo
193 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
