Problem for IBM Typewriters
Generic problem for all IBM Typewriters
I have an IBM Selectric III that has bee...
I have an IBM Selectric III that has been stored for a couple of years. Before storage it worked fine, but now it just idles when powered up and nothing operates. I assume this means it needs lubrication. How do I lubricate it to get it running again? Thanks.
Best Solution
posted on Nov 09, 2009
Rank: Wiz
Rating: 79%, 5 votes
Typically a machine that has been out of use, but was previously working may just need some lubrication on the motor centrifugal clutch assembly, but the entire machine probably would need lubrication also. You can first try to hand cycle the machine by grabbing the shaft that the carrier travels on and rotating it towards the (top to rear) rotation. This shaft rotates on revolution per print cycle and at rest the slot is slightly towards the rear of the machine. If you must lubricate the machine, then remove the cover. Lift the lid, place each hand of platen knobs and with thumbs, push down on release latches, after platen is out of machine, reach inside left and right cover and release the top cover latches and pull the cover straight UP to remove. Use 10 weight oil on motor bushings and centrifugal clutch hub (motor shaft).
Was this helpful?1 person thought this was helpful
Asker's Testimonial
Thanks, I'll give it a try!
" - betenoir
Popular Solutions for Typewriters
Questions and Unsolved Problems for Typewriters
My GX-6750 is not working well I just changed the ribbon and the letters and numbers are printed...
(More)
My GX-6750 is not working well I just changed the ribbon and the letters and numbers are printed dull and I also notice that the ribbon is not moving when I am typing
The left margin of my old IBM selectric is stuck way off to the right. How do I reset the left...
(More)
The left margin of my old IBM selectric is stuck way off to the right. How do I reset the left margin?
cannot write but carriage slides ok
how do you read a ascii file created on a smith corona pwp365ds 3.5 in floppy on a pc with 3.5in...
(More)
how do you read a ascii file created on a smith corona pwp365ds 3.5 in floppy on a pc with 3.5in floppy. I can use dos 3.3 - 6.2 or windows 98,xp.
