Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Problem for Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirpool Ultimate Care II washer - drips
By tinas555 on Nov 08, 2009
I have a Whirpool Ultimate Care II washer - model# LSQ8520JQ1 - I misplaced the manual... there is a drip coming from the inside top of the machine (where the water pours into the washer). What can I do to try to fix this problem?
Solution #1
posted on Nov 08, 2009
Not Rated)
jumptrout51
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 89%, 1022 votes
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Ultimate Care II
Questions and Unsolved Problems for Whirlpool Ultimate Care II
Do you recommend Whirlpool Ultimate Care II LSQ9564J Top Load Washer?
Answer
Answer
I have a small water leak from under the right front bottom.
Answer
Have Whirlpool washer Mod LSQ9264HQ0 fills with water and stops. Won't go forward will add more... (More)
Answer
Ultimate Care II has intermittent spinning and a small oil leak at bottom
Answer
water is in machine with clothes, agitated, now won't rinse.. when I put on rinse cycle is buzzes. ... (More)
Answer
washer agitates and is filled with water... will not do the rinse cycle, makes a buzzing sound when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Ultimate Care II...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14896
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
