Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
ok hears the deal, our Dometic Rm2652 Refrigerator, it started out with water dripping from the...
(More)
ok hears the deal, our Dometic Rm2652 Refrigerator, it started out with water dripping from the bottom (looking at it) right side... sooo my husband shut off the water to the line, for the ice maker... now it is freezing all the food on the middle shelves no matter where I set the thermostat... Please Help... We live in a 38 1/2 foot Alfa Ideal, fifth wheel, on a Island, it is skirted, and hooked to a 100 gallon propane tank, so hauling to where we got it is out of the question... we are retired , and live on a fixed income, so price is important also... ... Karen...
AC input power to fridge doesn't work. DC Power / Gas does work. Fuses are good on control board....
(More)
AC input power to fridge doesn't work. DC Power / Gas does work. Fuses are good on control board. and there doesn't seem to be any damage to the board. The Main Power ON switch works with DC but does not come on for AC.
