Most likely a bad bake element. Turn off the power to the range. Remove the oven racks. Remove the retaining screws holding the bake element to the rear wall. Carefully pull the element terminals out of the rear wall. CAREFUL now,the wires will be short. Remove the wires. If you have a volt ohm meter you can test the element for continuity. Set the meter for ohms or continuity and touch one meter lead each to the element terminals. If you get no reading replace the element with a new one. If you do get a reading your ERC clock is bad.
Was this helpful?
Yes
No
Popular Solutions for GE JKS05 Electric Single Oven
JKS05 oven- The fan will not turn on. I suspect the fan switch which should active the fan at 215...
(More)
JKS05 oven- The fan will not turn on. I suspect the fan switch which should active the fan at 215 degrees f. The schematics indicate that the switch is resetable. The switch I have does not have a button? Is there another way to reset the switch. How much is a new switch?
Temp seems to be all over the place....even seems to not heat some times but power is fine and then...
(More)
Temp seems to be all over the place....even seems to not heat some times but power is fine and then the oven gets real hot.
I have a GE stove - model JBP26OF5AD - and I need to know about the automatic oven cleaning function...
(More)
I have a GE stove - model JBP26OF5AD - and I need to know about the automatic oven cleaning function as we do not have the owner's manual. Help! Thank you.
