Internet and Communication Software
Problem for D-Link Internet and Communication Software
Generic problem for all D-Link Internet and Com...
My internet keeps dro, i have installed fil...
By quicksilv260 on Nov 08, 2009
my internet keeps dropping out on me, i have installed filters for wallsocket and phone, replaced my router and had a technician check the wall socket iv even done a isolation test without any success , i have seriously ran out of ideas, my isp company has blamed the filters then they said it was the wiring, then the router so i have done everything they have told me to do and its costing me too much money please help
Best Solution
posted on Nov 10, 2009
Very Helpful)
chinmay_pat
Rank: Guru
Rating: 89%, 21 votes
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Was this helpful?
Yes
No
1 person thought this was helpful
This Problem Also Relates To: D-Link VPN Client DS-605 (DS605) for PC
Questions and Unsolved Problems for Internet and Communication
Answer
Lg KG195. I cannot connect my phone to my pc and I have no cd
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link Internet and...:
Top Internet and Com... Experts
Rank: Guru Guru
Solutions: 1357
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Internet and Com... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
