Question about Emerson Black Microwave Oven
Food want get hot
I just bought this microwave in july 07. I can't believe it is already broke. Does anyone know what could be the problem?
Magnatron is the problem you need to replace it. I believe that this is still under warranty, so you can get a replacement free of charge.
Posted on Jan 06, 2008
I usually just put the food in a microwave proof bowl and put it it and push the button number that I think will be hot enough but not so hot it will burn my mouth .1 or 2 minutes is more than enough for most 30 to 50 seconds for coffee and 10 to 15 seconds for pastry
Sep 03, 2015 | Microwave Ovens
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
Hello, We received a Magic Chef Microwave Oven, MCD1110WB / MCD1110BB yesterday (8/31/11) to use in our workplace kitchenette. We are accustomed to having the microwave light come on when any...
We have the same oven, and the light comes on only when the oven is operating. When the door is open, the light is not on. I would be interested in knowing if anyone has done a work-around to make the light come on when the door is open.
Sep 01, 2011 | Microwave Ovens
Kitchenaid Microwave plate broke (you know the glass one on the bottom of the microwave) can I still use it to cood my food?
yes you can if you have an old plate that will fit on the rollers use that,, the only reson the food go's round is so that it is evenly cooked and thats all, plus it looks flash?
Mar 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
The glass turntable broke in 3 pieces this morning while cooking bacon. The bacon was not yet cooked or even hot. It broke into 3 large pieces. The unit is not at all new. Does this sound normal? Did I do...
The same thing happened to my microwave this morning while heating a cup of water, which broke into 3 pieces too before the water hadnt even hot.
Maybe you have already solved your problem and I just share my experience.
I am trying to call the manufacturer nearby and ask for the turntable, but I am afraid the new turntable dosent fit my a little bit old microwave.
Dec 27, 2009 | Microwave Ovens
The paint (or whatever it is covering the bottom)
Check the 3 wheels on the circular plastic part that's fitted below the turntable.
It sounds like they may need some filing down. Run your fingers around the wheels to see if there are any sharp bits of plastic that could be cutting into the paintwork on the base.
Clean out the base of your oven and apply a thin film of vaseline to each of the 3 wheels. This will help rotation in future.
Remember to keep cleaning out any excess food particles that may lodge below the turntable, as these will eventually slow down or stop the rotation, which in turn means that your food is not heated evenly throughout!!!
Nov 18, 2009 | GE JE2160 Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
It won't get hot no more won't get hot at all it won't cook no food
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Sep 09, 2009 | Goldstar MV-1526 Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Emerson Black Microwave Oven Logo
53 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
