Question about Toshiba 32A50 32" TV
No Color I had an issue with the screen turning to static a while back ( and no the cable was not out). Took it to a tv repair shop in my home town and he suggested the easy fix was to use a video input rather than the antenna. That was fine (and cheap) and it worked for a while. But now the issue is that the color is now gone regardless of input (cable, DVD, vcr, etc). Anyone have a clue what the issue may be? Thanks in advance for the help.
  • 55 Answers
I dd understand that you have a color problem on the tv -you have to repair it - delfo
Posted on Mar 14, 2008
My Philips Plamsa won't turn on, has a black screen but the power light is on. There is also a constant clicking noise. Any ideas of what this might be. The tv is a couple of years old.
The picture is White or Black:
1. Adjust picture setting such as brightness or contrast
2. Check the color settings
3. Check to ensure you cable connections are connected properly.
Jan 20, 2011 | Philips 42PFP5332D 42 in. Plasma...
Color halo's on screen
On old style CRT TV's there used to be a Degaus button that nuetralized any static build up inside the tube, and corrected those "Halo" or Color ghosts on the screen. You can take a very strong magnet and pass it a few inches in front of the screen. Try sweeping the magnet across from left to right until you have accurate colors again. (Takes less than 1 minute)
I have a CR202 EM8 and I have had to do this a couple times over the years. On my cable system I can tune in a Color Bars pattern on channel 2, which makes it really obvious where the static build up it affecting your colors.
Good luck...
Jul 31, 2010 | Emerson CR202EM9 TV
I have a Magnavox TV/DVD and i recently had a power outage. The power came back on and turned on the TV and the color of the TV screen is a purple or green tint. There is only a tiny circle about 1 inch in...
Remove the the plug from the wall socket(power) plug it back after five minutes. If the power outage was caused by lightning, then it is most likely static on the screen.
Regards
Phillip
Sep 12, 2009 | Televison & Video
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Getting a shadow or double image
had a connection error 2 wires were crossed
Dec 04, 2008 | LG 37LC2D Television
No picture
My parents bought the same tv, TV ran fine for 2 years then started giving them problems. Blue light comes on then few seconds later turns to yellow. Turn tv off then back on it worked, until last week it would not turn on.
Took it to a repair shop they said it was a bad power supply and it will cost 50$ for this check up, as it turns out the total bill would be $650 minus the original $50 it would only cost you $600.
Needles to say i took the tv home with me. Since they were not going to use it i started looking at it took the back off, removed all heat shiels ect. Took my magnifing glass out and started looking at the power supply come to find out the part was made in China, it was missing a solder joint, pulled my old soldering gun out, five minutes later the tv came back to life.
i hope this helps.
JOHN
Oct 23, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Cable connection generating static on screen & noise
Hi, it sounds like ya most probably gonna haveta resolder the Cable Connection Socket internally.. they often fracture, OR perhaps it is the Actual Cable Connection Plug itself?.. maybe you need to remake this input connection? Indeed it sounds as if the Earth Shielding is making bad contact...
Sep 04, 2007 | Toshiba CF36G40 36" TV
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
Aug 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Toshiba 32A50 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
