Planar PL1700  17 in. Flat Panel LCD Monitor
Problem for Planar PL1700 (Black) 17 in. Flat Panel LCD Monitor
Monitor setting panel on permenantly
By mrjk65 on Nov 08, 2009
Planar 1700 black flat panel monitor:
the monitor settings panel is on and won't go away. the adjustment buttons have no effect.
is this just the end of the monitor or can it be fixed?
Solution #1
posted on Nov 08, 2009
Not Rated)
12fixlouie
Rank: Guru  Computer Hardware  Expert
Rating: 96%, 48 votes
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Was this helpful?
Yes
No
Popular Solutions for Planar PL1700 17 in. Flat
Questions and Unsolved Problems for Planar PL1700 17 in. Flat
Do you recommend Planar PL1700 (Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
The OSD menu has decided to always come on and the selector is moving around the perimeter so you... (More)
Answer
colored box in the middle of my monitor with an r-g-b blinking up and down also has an exit but i... (More)
Answer
I can see the screen but it is just very dim. I tried the auto settings but it didn't work
Answer
I need to find a Planar monitor stand for a PL 1700M. Any suggestions?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Planar PL1700 17 in. Flat...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
