Toshiba 36A43 36" TV
Problem for Toshiba 36A43 36" TV
I have a Toshiba TV model 36A43 that won't power
By jazzysax1976 on Nov 08, 2009
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred and I unplugged it for a little while and then it worked. The picture was perfect as usual, but the volume down display kept popping up on the tv. I have the unit connected through a stereo system, so I don't even use the tv speakers, but the pop up was a bit annoying. I shut it off last night and this morning it won't power up again. I noticed today that when I unplug and plug it back in the red power indicator button flashes, but it won't turn on even after being unplugged for a couple of hours now.
Solution #1
posted on Nov 11, 2009
Not Rated)
rusty_etech
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 91%, 120 votes
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Was this helpful?
Yes
No
Popular Solutions for Toshiba 36A43 36" TV
Questions and Unsolved Problems for Toshiba 36A43 36" TV
Do you recommend Toshiba 36A43 36" TV?
Answer
Answer
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get... (More)
Answer
Toshiba 36A42 controls (on/off, volume, channel, dvd/vcr/tv selection) will not work.
Answer
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using... (More)
Answer
Our Toshiba 36A43 was just repaired. A new power supply was put in, bring home and volume goes down... (More)
Answer
i can not get my TV to change from video to tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
