Home | GE | Profile 26.6 cu. ft. Side-by-Side Ref... | Water in door is not com...
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Water in door is not coming out very much intermiient
By stovefam on Nov 08, 2009
When when trying to fill a glass of water in door the the flow is really slow.
Solution #1
posted on Nov 08, 2009
Not Rated)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 561 votes
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
no water to ice maker. I think water shute is frozen, because I can get water to the door. I have... (More)
Answer
Ice maker in our GE profile refrigerator is not making ice. The water dispenser works. The green... (More)
Answer
ge profile refrig pss265sgpa ssfg 409236 has a leak in the icemaker and now am having odor when I... (More)
Answer
GE Profile Refrigerator (PSS26MSWASS) The ice dispenser intermittently dispenses ice. Checked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
