Possible reasons are : Case 1: You have just less memory RAM(ex:256 Mb ram) and u have many applications opened during startup and many services than the threshold. Use msconfig(XP) or Gpedit.msc(Win Vista or 7) and remove unwanted services and startups.
Case 2: You would have recently visited any wares sites or any misleading sited which would have uploaded a spy virus.
Case 3: Trojan and worm32 presence in your system.
Case 4: Missing system files too.
Solution:
Either try to increase RAM size in a situation like "case 1".
Or do a clean check of your system for virus using antivirus AND a ant - spyware virus.(Note antivirus and Anti spywares are different. So use both).
ok, download this programs if you can, ccleaner, spyboot search and destroy, atf cleaner.. put you computer in safe mod ( when booting hit f8, or f2, --it is based on you bios in most cases it is f8) you will come to list view of how to start your pc chooes safe mod on the top.. coputer in this mode should run faster.. check the speed, run ccleaner, spyboots annd atf cleaner.. after that run defragment tools, also check you computer for viruses... restart computer and it will start normly .. see if there are chenges in speed...post me back after that ..
3 things are known to case this issue. 1.There is a lack of available system memory - The more available RAM the better especially when editing video 2.There is a lack of available disk space or swap disk space - swap space is used as soon as the memory is unavailable and really sows everything down to a snails pace and sometimes this can mean only processing a few bytes every minute - not very good when editing huge AV files. As a guide you need approx 10-20% free space on the Hard drive to make sure the PC operates efficiently. 3.There is a driver problem. This can be a video driver issue and often needs an update in the video card being used. Graphics and Video editing demands a lot of processing. If this persists then it would be a very good idea to uninstall the application and drivers and then to run a Registry clean using the Ashampoo tool (available free of charge for 30 days from www.ashampoo.de) to make sure that all instances of the driver and application have been removed so as not to cause any contention between drivers and applications. Then reboot the PC and reinstall the application from scratch.
You should also check for any updates to the application that you are using especially if you have applied XP updates or service packs recently as sometimes the service packs can seriously upset applications.
i have an older model gateway e series pc and need to install the cdrom hardware and do nont seem to...
(More)
i have an older model gateway e series pc and need to install the cdrom hardware and do nont seem to be able to remove the housing face how do I do this
Hi, I have installed Realtek ALC888S driver on an Acer lowcost PC but the device 'HD AUDIO' shows up...
(More)
Hi, I have installed Realtek ALC888S driver on an Acer lowcost PC but the device 'HD AUDIO' shows up twice - once with the working driver and secondly without driver installed. So I remain with one device that has no good driver installed. The effect occurs both in Windows XP and in Windows 2003. Anyone any ideas? Tks Ronald
HP Pavilion Slimline s3122x powers up fan runs but no monitor working or keyboard took to shop was...
(More)
HP Pavilion Slimline s3122x powers up fan runs but no monitor working or keyboard took to shop was told it was shot what's up with that he also wanted to build me a nice computer I bought another HP would like to repair this slimline if possible not quite 2 years old
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it...
(More)
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it something i need to add to pc
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on...
(More)
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on other people's myspace pages when it's imbedded into the page as an mp3; however I cannot hear the music on peoples Myspace Music Players. This started late yesterday afternoon and of course I presumed this to be a myspace problem and didn't give it much thought. When I turned on the computer today something visually went by fast (maybe a small gray java window) like it was installing something (maybe windows haha) but it may have said Windows Media Player. When it finally came up I opened Windows Media Player and tried to play an MP3 and it said I was missing a codec and provided a proper link. I clicked on the link and immediately got the codec and now the MP3s play. But still Myspace Music Players don't play. Here is the bad part that made me realize it wasn't a myspace problem. My midi files do not play nor do any of my webpages play the midi files on them. The only change I made was yesterday I deleted X-Vid codecs that I had downloaded months ago and did not use. I used add/remove programs and removed X-Vid. Anyway I did a full Nortons scan and was clean. Then I ran a full Ad Aware Scan, and ran CCleaner as well and nothing is very wrong with my system other than no sound with midis. I finally decided to do a full system restore to yesterday that failed as it said I had made no changes. Then I tried a system restore to last Sunday and it said there were no changes made and so no restore would be made. So it probably wasn't the X-Vid delete that caused the problem. In troubleshooting in Device Manager I tried to update ALL the audio drivers and it said I had the best (latest)version of all the drivers. I clicked on everything individually and then ran the troubleshooters which took forever. I have no yellow exclamation points and it says all things are working properly. except for one thing. when I click on Unimodem Half-Duplex Audio Device it says this device is working properly. When I click on properties and then again on the tab that says properties and then on the words Modem Wave Driver it says Status:Driver is enabled but not functioning properly. Yet previously (higher up) it said it was fine. (this is device 5.3.2600.2180) Also if I click on Control Panel, Sounds and audio devices,sounds tab.... and click on a sound.... it used to let you preview the sound but now the tab is gray. I don't know what to do next. If my sound card was unseated my mp3s wouldn't play. I have rebooted several times. I have tried reading Dell forums (I have a Dimension 5100) and I have read forums for Unimodem half-duplex audio device and forums for Sigma tel High definition audio codecs although that one says its working properly. Since it seems to only be Midis affected and it is called a Modem Wave Driver, could the dial up modem be unseated? could it be that simple?
