Question about Dryers
Cannot open Maytag DE410 eletrical dryer to apply luiblican.
  • rjlto Jul 03, 2008
    What are the "capacities" of the following old models (looking to upgrade or match capacity on a new one)?
    Maytag Washer A106 #042273ZQ ?
    Maytag Dryer DE410 #283538 LG ?
  • Anonymous Mar 30, 2009
    i have a maytag DE410 and i've looked for these screws but didnt find them. the only screws i see are on the sides of the dryer.can you please help me?
  • 51 Answers
You will find two screws about two inches up from the floor. You can't see them if you are standing up. Unplug the dryer, remove the screws and pull the bottom front out.
ps, It's best to replace a noisy part, the noise will come back.
Posted on Jan 10, 2008
Maytag electric dryer de410 trouble shooting! How do I remove the cabinet?
There should be an element behind the spin drum,take cover off the back to undo drum.
Jul 26, 2014 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
My Maytag DE410 dryer is not working. When I press the start button there is a buzzing sound, however, the drum does not move and the start button does not stay depressed.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Re Maytag dryer model DE410, serial number 285802, series 01. How much of machine needs to be taken apart to tighten blower fan on end of motor shaft. Thanks. Murray bally.duff@sympatico.ca
Sorry to read about your problem, I hope this helps you out.
all most all of it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Maytag Dryers
My dryer won't heat. Maytag DE410
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day. Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
I need detailed instructions on how to replace heating element of a Maytag DE410 electric dryer including diagrams...Dryer does not heat...
Very simple. Remove screws at the base and the front panel. The heater is on the bottom easily accessed. The re-string kit is way cheaper than the "mailbox" Start here:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 04, 2009 | Dryers
Maytag DE410
Replace the drum seal. To do this you need to get under the machine and start removing the pieces, IE pulley, clutch, brake. Until you get to the main bearing and the seeal. At the same time check to make sure that the bearing is still good since the seal has blown
Feb 13, 2009 | Maytag PYE3300 Dryer
Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Sep 02, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
329 people viewed this question
Top Dryers Experts
Marvin
Marvin
