can you hear the motor running when you turn it On?
try to open the back of your machine, you can see inside the motor, belt and other mechanical parts, try to turn it on while looking at the parts but DON"'T GET TO CLOSE,
If the motor is running and the belt is NOT, then UNPLUG the unit, tighten the belt just a little enough not to slip away then try it, it should be a little loose
Was this helpful?
Yes
No
Popular Solutions for LG WM2277H Front Load Washer
I would like to remove and clean around the front door seal of my LG WM2277HS front load washer and...
(More)
I would like to remove and clean around the front door seal of my LG WM2277HS front load washer and although it doesn't look that complicated, I'm sure it's not as easy as it looks (nothing ever is). I was looking for a parts list for the machine which usually shows an exploded view but no such luck. Can anyone provide guidance on this? Thanks, Dennis
I am getting a weird Error code. It looks like a small "b" and a "E", but the...
(More)
I am getting a weird Error code. It looks like a small "b" and a "E", but the small b doesn't have the right side of the letter. Some what looks like a upside down F.
