Question about HP (5064-6630) Motherboard
No video changed cpu, now for some reason the screen doesn't come up. the video card turns on and you can also hear the hdrives turn
    Sergeant:
    Champion:
  • 243 Answers
Did you reset the bios using the cmos jumper on the motherboard?
Do this with all power off.
What cpu did u have and what did you upgrade to?
Posted on Jan 06, 2008
6ya staff
SOURCE:
Monitor screen is black but computer seems to work
That is not enough info, please provide more info so people can understand the issue better. For example, describe what you do and see step by step. When you turn on the machine, after a few seconds it powers on, it should run Power-On-Self-Test (POST) which will end with a beep telling you everything was OK. If you do not hear any beep, the problem is likely to be inside the case, bad video card, motherboard, CPU, etc. Typically bad RAM or Video card will cause a series of quick or long beeps (different for each motherboard) to indicate where the problem is. Bad CPU generally do not generate a beep code and most motherboards also do not give out a beep for motherboard issues, naturally.
If you hear that beep but see absolutely nothing on the screen from the moment you turn it on, then check to see if the status indicator light (assuming it has one) changes color or not:
A) If the light on the monitor changes from red/amber to blue/green but you see nothing on the screen then either the video resolution and/or refresh rate is unsupported, video drivers are faulty or monitor itself is bad.
B) If the light goes back to red/amber or stays that way from get-go, then there is no connection, monitor cable is loose at either end or bad/supported.
C) One other possibility would be the input selection on the monitor which is set to "Auto" by default but if it was manually changed to DVI for example and you are now using a HDMI cable, monitor would not automatically change this setting thus not receiving the signal from the video card. You can check this using the menu buttons on the monitor itself.
This is a generic troubleshooting ideas I just shared, more details you can provide, the better people will be able to assist you.
Nov 21, 2013 | Dell Dimension XPS 400 PC Desktop
MCP73VT-PM
Mmm that's not a good sign since the computer have integrated video card there a little chance that your motherboard has died, everything you would hear that is power on because the power supply do work properly but if the monitor doesn't show anything or do not hear any beeps, that probably means that your motherboard is dead.
Jan 11, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
I have an elitegroup k7s5a pro. every time i turn it on all i get is a black screen.i have replaced the video card more than once an with one that i know is good so i dont think it is that ,can u give me...
with the error of video card, you can hear the warning beep of mother board.usually one long two short. if you don't hear anything .check memory card or cpu is installed firmly.
Oct 28, 2010 | EliteGroup K7S5A Pro Motherboard
When i turn on my CPU, i can only see the light of the Cd rom drive, my screen stays black. but i can hear the sound from the CPU that it is on and the fan at the back is working.
If this is a desktop, some of the components may need to be reseated. The memory chips, perhaps a video card if it has one, something like that. Generally what you want to listen for are beeps. In some cases you will hear a slight clicking sound. That usually indicates a hard drive failure. Put a CD in the drive and see if it gives you a different message.
Jan 17, 2010 | Computers & Internet
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Motherboar fail, no video, power supply ok help
Firstly, remove the RAM and turn on the system, if you hear the beep sound continuously that means everything is perfect expect RAM.
Clean the track of RAM at both sides by pencil eraser completely.
Also clean the port of RAM.
Secondly reinstall the CPU with CPU FAN and also clean the FAN.
Third one is that remove all the add-on's card and than turn on the system.
Apr 12, 2009 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
I turn my computer and i hear a three beep code continuously but the screen did not display anything
hi,
3 beep code is a video card mis function. try taking the video card out only after you disconnect the power cord and touch the cpu case to take the static from your body and make sure it properly seats into the slot. then restart your system if this doesn,t work and you continue to get the 3 beep code it will most likely time to get a new video card.. if the card is a built in card and you have available slots on *********** board try adding another card . depending on the age and brand of computer you coomputer will auto recognize another card and work or will ask you which card do you want tio use in this case prompt for the new card and it will contintue to use it. good luck .. thanks..
Mar 30, 2009 | Asrock K7S8XE Motherboard
Computer gets power, but doesn't display anything
remove your video card and plug it again.. if it doesnt work..
try plugging ur video card to *********** board built in video card and then ur on-board video card to you monitor..
this is what the nvidia guys mentioned on their video while announcing the release of the 9 series
May 07, 2008 | Toshiba Satellite P25-S607 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
