Question about Lexmark MFP-X3470 All-In-One InkJet Printer
Cover tab broken on Lexmark X3470
The tab for my printer cover broke when I replaced my ink cartridge, now the display window reads cover open. My printerwon't power down or operate.
  • babydluv06 Apr 12, 2008
    do not see anything broken but printer say cover open it will not turn off or do anything
    Scholar:
  • 48 Answers
Have you recovered the tab? All the tab does is interrupt a sensor beam between 2 points. Either glue it back on (epoxy or super glue, use sparingly on one side then apply and hold down until it sets, about a min. or tape a popsicle stick into the area where the tab rested. First feel around with the stick in the area until the printer responds. then fix it there.
Posted on Jan 06, 2008
6ya staff
SOURCE:
I changed the ink cartridge and now the printer screen reads "cover open"
Sometiems you have to close the covers firmly to get the sensor to recognize that it is actually shut
Jun 16, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open displayed
you may not have pushed the cartridge down firmly enough wait till you hear a click same with the cover.
Mar 20, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
see your printer cover for broken.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
