Question about Garmin Forerunner 305 GPS Receiver
Won't power up off the cradle
I have tried the mode, power and reset "soft reset". I have upgraded the latest version off the webupdater. Says "charging complete" when on cradle or on the ac adaptor, but once removed from either, it is completely dead. It powers on and works when hooked to power.
I had a similar problem months ago and the reset worked. What am I doing wrong, or what else can I try?
  • carloslara Feb 24, 2008
    I had exactly the same problem. What should I do? Sent my watch to garmin? or is there any other procedure that I can do to revive my garmin Forerunner 305?
    Many thanks.
    Carlos
  • Tonerod Nov 25, 2008
    My 305 is just over a year old and just about a month or so ago I
    started have problems with the unit. Sometime it just would not power
    on at all unless it was in the cradle for awhile, even though it was
    fully charged. Once it was on it seem to work fine, so I didn't think
    at that time it was the battery. I tried all the reset procedures that
    Garmin suggested but still no joy! Now it will not power on unless
    it's in the cradle, but once removed it shuts off immediately. I think
    now the battery is problem. I was disappointed to read so many people
    had the same problem and in most cases the unit was just out of
    warranty like mine was. I hate to picking any sealed apart. They
    never seem to go back together the same way, but if I find a
    replacement battery for my 305 I will give it a go.
  • 3 Answers
I had exactly the same symptoms as you (and tonerod)
Others may just want to be aware: When I tried to use WebUpdater to install 2.80 rather than the installed 2.70, it got only so far through the process, detecting the installed version and deleting it but (I presume because of connection problems), failing to install the latest version, leaving a "No software" message on the unit (although subsequent attempts detected the original 2.60 was still there, it would get no further through the process)
My issue turned out to be a problem with water ingress and internal corrosion of the charging/interface contacts - I think the battery was still good as it had been charging and holding that charge fine WHEN a connection was made).
(on opening unit myself - see http://www.fixya.com/support/t486586-will_not_power_up_out_cradle)
If careful, give it a go yourself...but be aware that this would invalidate your warranty (if its still running) - a significant concern is the apparent frequency of these problems just after the warranty expires!!!). Not sure if Garmin would still repair your unit/replace the battery after warranty, so may be worth contacting to find out...best of luck with THAT!!!
Posted on Nov 25, 2008
i have had the same problem for the past month. just seen this post and though i'd try to power mine up in the cradle as it does not power up out of the cradle. when i done this it gave a read memory error message. i sent it away to garmin tech support to see what they say. but i am having trouble with my laptop also giving these read error messages. does your computer do this or anything like this or is it low on memory?
Posted on Jan 18, 2008
  • Anonymous Jan 27, 2008
    Going throught the net there seems to be a lot of these kind of errors with garmin, not only the 305 but other models. i got this mail from the tech support.
    The GDX_FITNESSXFERTHREAD.CPP error can occur while trying to transfer data to the Training Center or from it to the Forerunner or Edge units. I would suggest updating the version of both the unit being used and the Training Center , to make sure that both are at the most current versions. Before updating the unit software you might want to download the data to Motion Based if the data is important to you. Updating the unit software may erase the stored data on the unit, you will not be able to transfer the data from Motion Based to the Training Center , but at least the data will not be lost. I would suggest updating the version of Training Center first to see if that corrects the problem first. Motion Based if you do not have an account is www.motionbased.com you will also need to create a myGarmin account if you have not already done so. You can go to www.garmin.com and click on the link for myGarmin, and then click on create new account.
    Here are the links:
    Forerunner 305: http://www.garmin.com/support/collection...
    You can also try to delete the laps one at a time from the unit, and after each lap has been deleted try to once again transfer the data until you are successful. This will allow you to find the problem lap without having to delete the entire history on the unit. This way you can save some of the recorded information on the unit.
    Now that you have deleted the lap or workout causing the problem and have been able to transfer the data to Training Center , you should not have to worry about this problem occurring again.
    Original Message Follows: ------------------------
    i bought a forerunner last year off the internet. in the past month or two when i have gone to use it it wouldn't power up out of the cradle. when i put it into the cradle it seems to have trouble connecting to the computer. when it does connect it gives a message saying that it is having trouble connecting. i have tried leaving it to give it a good charge. this time i tried to power it up when it is in the cradle an it does power up but it gave a message saying to copy the message and send it to you.
    do you have any suggestions on what to do? does the garmin program need to be reinstalled?
    also i found this on slowtwitch
    http://forum.slowtwitch.com/Slowtwitch_F...
6ya staff
SOURCE:
Garmin froze on erase
Try performing a soft and or hard reset on the GPS.
The soft reset is done with the unit disconnected from the power cord, press and hold the power button down for at least 10 seconds until the Garmin screen is displayed.
The hard reset is done with the unit disconnected from the power cord and the unit off, press and hold the lower right corner of the screen and press the power button. A prompt will appear asking "Do you really want to erase all user data?". This will erase all favorites that were saved to the unit. Press yes to reset the unit to factory specifications.
Run the Garmin WebUpdater program to install or reinstall the latest software for your device. This will usually fix any issues.
Be sure to download the correct version for PC or Mac.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 02, 2012 | Garmin Nuvi 1340T 44 in GPS Receiver
Garmin Nuvi 1450 will not turn on
1-800-800-1020
Dec 25, 2011 | Garmin nuvi 1450 GPS Receiver
Gps just flickers the garmin lname
Try performing a soft reset.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Oct 17, 2011 | Garmin Nuvi 1300 4.4 in. Car GPS Receiver
Should have mentioned that the audio on the Garmin Nuvi 1450 works fine but the screen is usually partial and it freezes up.
Try performing a soft reset or a hard reset to the unit.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Sep 28, 2011 | Garmin nuvi 1450 GPS Receiver
The audio works fine but the screen is incomplete and is frozen
Ive had a nuvi 1490 LMT for 3 weeks now and the screen has gone inky and wont display anything, although if you touch the screen in the right place you still get the beep It has deff not been dropped snd...
Sep 28, 2011 | Garmin nuvi 1490T GPS Receiver
Touch screan does not work on nuvi 760. Everything else works. Does not respond when touching screens. Can't change menus
The soft reset is done by holding the and sliding the power button on for at least 10 seconds and allowing the unit to power on.
Sep 28, 2011 | Garmin Nuvi 760 Car GPS Receiver
My map appears but their are no roads shown
Try performing a soft reset first or a hard reset if necessary to the unit.
Sep 22, 2011 | Garmin nuvi 1450 GPS Receiver
My Garmin 305 shuts off when I pause during a run. If I stop mid-run and pause my Garmin THEN hit start to continue it shuts off instantly. Is this fixable?
Try resetting the unit by pressing the "Mode"(reset/lap) and "Power" buttons at the same time.
Also, be sure that the unit has the latest update.
Reloading the latest update will resolve most issues.
Sep 19, 2011 | Garmin Forerunner 305 GPS Receiver
Intermittent satellite loss after upgrading Maps to the latest NA version.
same problem after updating type G GPS firmware 2.90 to 3.0..
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
494 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
