Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Lcd sharp tv flashing green light
Power went out in our city, then when we went to turn tv back on, it will not turn on, just keeps flashing the green power light
  • 6 more comments
  • bfj2008 Jan 09, 2008
    I'm having the same problem the "opg" light is flashing also.
  • OCRegulator Jul 01, 2008
    Thank you CET. Your posting on 02-05-2008 was just the solution my wife and I needed. We followed the simple pattern of holding the buttons as described, and SHAZZZAM!!! Our TV worked again. Only afterward did we recall a power outage that was the probable culprit. Your simple tip probably saved us at least $200 in ridiculous service fees. Thanks again!
  • jkychu Aug 18, 2008
    Was watching a dvd on my Sharp Aquos LC-32D43U and it went black for a second and then the green light started flashing (the power light, I think) but only the one light, not two like other people have experienced. I didn't see any red or blue lights - just green. I've had it for a year and a half so the warrant has expired (figures). I tried two suggestions: 1) holding the power button, unplugging the set for a count of 10 sec. and then plugging it back in for another count of 10 sec. and releasing the power button; and 2) holding both the volume + and channel - while unplugging and plugging back in and both to no avail. Any one got any other suggestions? First time I"ve had any problems with them tv - pity b/c it was working so well until now...
  • Anonymous Jan 06, 2009
    Power light flashes blue on and off again. Help
  • bdspvl
    bdspvl Sep 19, 2012
    Thanks guys, It worked for me. Also found out if you turn the brightness down it stops shutting down. If the brightness is full the tv shuts down. has to do with the brightness circuitry.
  • Anonymous Mar 31, 2014
    front light keeps flashing
  • Myko Dec 01, 2016
    Yes your tip worked for me I have a sharp aqueous 55 inch and I had the green flashing lights and I pulled the plug out and held the voulum button up and the channel button down and then plugged it in at the same time and it worked but you have to press them simultaneously and let someone else plug it in and see what happens for you but it definitely worked for us...thanks for the tip again I contacted sharp and they didn't know what to do I would had paid $200 to fix it up to them goggle is very resourceful.....
  • Tina Russell
    Tina Russell Dec 18, 2018
    I did the volume up and channel down thing and nothing my TV is still black. Blue light is on ...
    Champion:
  • 208 Answers
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Posted on Feb 05, 2008
  • 13 more comments
  • Warcila Nov 30, 2010
    thanks, I am a service member station in Germany.
    I called the 1800 number for Sharp but all they
    Said was you need to get it serviced. I did as you
    Said and held the volume an channel button and bang my 37" Sharp cristal
    LCD is working. Thanks so much you saved me a lot.
  • RDRCM Dec 01, 2010
    We had a power outage, our Sharp Aquos would not turn back on. We had the dreaded green flashing power light. We held the volume up and channel down buttons in while we plugged the TV back in. The TV reset with volume. About 10 seconds later the picture was gone but we still had volume. We turned the unit off using the Sharp remote, turned it back on and Walaaaa.....We are back in business. Thanks for your feedback......it helped~!
  • S223542 Aug 04, 2011
    THANK YOU!!!!! WORKED LIKE A CHARM!!!!!
  • Shim Oct 23, 2011
    I have sharp lcd42dh77e tv. When power is on it only shows green flashing light. Tried reseting by holding the power buttion for 10 sec. green flashing goes off, sounds comes for a while, channel number can be seen on the top and again back to the green flashing light! what is problem and solution? I had this problem twice before and solved by reseting but now its not working.
    Tried to enter in the adjustment process mode by following the steps stated in the service manual (Vol- and Input button) but failed,tried the steps stated in your solution and again failed, is there any other way?
  • Giuseppe Nov 27, 2011
    I get a 1b lamp_error 00h 00m.
    How can I solve it?
    Thanks a lot
  • lifes_a_beac
    lifes_a_beac Feb 24, 2012
    Thank you. Just tried this on my 37" Sharp and to my disbelief it worked! Has saved me from an expensive call out charge.
  • melissa_ycss
    melissa_ycss Aug 28, 2012
    Is there a way to do this without a remote?? I picked one up on the side of the road that is doing this. We held down the channel and volume button and when we let go the screen came on for a few seconds then went black again. We don't have the remote to it. We plugged our phone up to the imput and it emits sound just fine.
  • melissa_ycss
    Is there a way to do this without a remote?? We picked one up on the curb and it doesn't have a remote. We pushed the channel and volume button as you said but no K came up. The screen came on and showed the imput and all but then turned back to black. The light isn't flashing anymore though.
  • De Davis Jun 28, 2013
    so far it work holding the volume up and channel down
  • Becky Glass Aug 23, 2013
    I'm having the same issue as melissa above; I pushed the channel and volume button as you said but no K came up. The screen came on and showed the imput and all, but then turned back to black. I clicked the channel up button on the remote, but still black. The light isn't flashing anymore though.
    I was able to get sound now using the volume up and channel down buttons, but I only get a brief glimpse of the channel, then screen goes to black. Is there other button combos for different problems?
  • Rachel Sep 27, 2013
    Hi Becky, I just fixed this issue using the following method: push the volume down button and the power button at the same time. Wait for the light on the front of the tv to turn red. Then turn the tv on. It should come on, and quickly push menu and go to settings and hit reset. Once the reset is over, the tv should be good to go.
  • Violet Jane
    Violet Jane Dec 28, 2013
    the power light is gren on my tv , but it wont turn on & if it does itll stay on for a second :( ';
  • skylar corey
    skylar corey Dec 31, 2014
    I had this same issue. all I did was unplug it. hold down volume up button and channel down button 9n the TV ( not the remote ) plug TV back in while pushing volume up and channel down. release buttons. TV will come on and green light will not blink anymore. press menu go to setup then go to reset. highlight reset then press enter. then highlight yes then press enter. TV then should reset and turn off by itself. once TV comes back on it should be good to go.
  • John Kidd
    John Kidd Jan 18, 2019
    I tried the remote buttons hold volume up and channel down together and picture returned
My sharp aquos will not turn on and it is flashing a green light at the base of the tv. I tried guru's suggestion and it didnt work. any other suggestions?
Posted on Jul 07, 2009
I had the same problem: green light flashing when i opened the TV. CET's trick didn't worked, well half of it.
I unplugged the TV. I hold down Volume Down and Channel Up on the TV (not the remote). Kept them down and plugged the TV. After 10 sec of waiting, it worked so I let go the buttons.
Dont know why, but it worked.
Posted on Aug 03, 2010
Great advice! I had a flashing red light on my Sharp Aquos LCD 37inch (6 years old) which meant I couldn't turn the tv on but after following these instructions it's back on - Thanks a mil !
Posted on May 25, 2010
We have a Power Up problem with our Sharp Aquos 52SE94U and have had this problem since we bought in on 6/14/08. Sometimes after shutting if off, it won't power back on when we use the remote, so we read to unplug and plug it back in and it will work and it does. But for the money we shouldn't have to do that with a brand new TV. We have the Aquos Advantage program and they've sent a tech out 2 times now. They replaced the main p-c board, still had the problem so they came back and replaced the sensor board. It worked for 2 days then we went right back to the same problem, won't power on using the remote. We are back to unplug and plug in routine. HELP!!!
Posted on Aug 06, 2008
First two stepsin Guru's approach worked. Great! Thanks.
Well, this is a very comon fault.
First check the inverters forcing the TV set in service mode : unplug the unit from the input box,press VOLUME DOWN and INPUT keys and while pressing them switch the TV on using the power button (not the stand-by key). Maybe you see error 5. This indicates an inverter failure but if the screen is visible equally then the fault is hopefully elsewhere.Reset to zero (refer to the service manual) the error,disconnect the TV set from the AC plug and remove the rear cover.Then remove the screw holding the middle main board and clean the screw holes and the screws with some good contact cleaner.Refit the main board and power on the TV again. 99% works.
Posted on Nov 12, 2011
I had the flashing blue light on an LC-37D90U. I held the buttons as suggested and plugged the unit in. It reset and my problem went away. There is no mention of a flashing blue light in the manual. Thank you for posting the info. Terrible troubleshooting section in the Sharp manual. They should be ashamed of themselves.
Posted on Apr 12, 2008
No solution, just saying thanks! My mother's sharp lcd tv went out with a green flashing light. Followed the unplug, vol + / channel - , plug back in, and my mother couldn't believe it! From Long Island, many thanks!
Posted on Apr 26, 2012
  • 1 more comment
  • slideordie_2
    slideordie_2 Aug 24, 2012
    when i followed this procedure the power light stays on steady now but i still have no image
  • Melonie Holcomb Mar 02, 2013
    me the tv flashes on for a second on channel 12 with static but then goes back off
  • kshaffer3064 Jul 12, 2013
    I had this same problem and the unplug, Vol + Channel -, plug back in worked like a charm. I'm going to add this to my Sharp manual. THANKS>
I used this solution to fix a blue flashing power light on my Sharp Aquos LC-52SE94U and it worked great. Thanks for your help as there was no solution in the manual.
Posted on Jul 08, 2008
    WORKED LIKE A CHARM!!!!!!!!!!!!!!!! THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    New Friend:
Ill put in my two cents. ok i had the same problem with my mom's tv. did the reset thing and it kept happening after a few seconds. i decided to move input off hdmi 4 and then it stayed working. so i switch ports. i think it might cause the error on that port cause the port might be bad now. now i got it to stay on everything else but if i goto port 4 it errors it out." class="_mp3rocket_overlay_style" style="left: ; top: ; width: ; height: ">
Posted on Feb 13, 2013
My sharp LC-32m400m-bk LCD flashing the red led
Posted on Mar 16, 2012
    New Friend:
I have a LC-32DH65S with the same problems. my solution was:
Unplug the power
Press menu and vol-
plug in power
release buttons
and voila it works again!
Posted on Feb 11, 2014
Great fix. Was waiting for the tech to call and decided to google the problem (flashing blue power indicator light) of no power. Tried the fix and voila!!. No tech for me.
Posted on Dec 15, 2008
    New Friend:
I have a LC-32DH77E, with the same problems. my solution was:
Unplug the power
Press menu and vol-
plug in power
release buttons
Posted on Oct 20, 2014
  • Francesco Colotta
    Francesco Colotta Oct 08, 2015
    Thanks Antonio very much !, this worked for Me, Unplug the power, Press menu and vol-down, plug in power release buttons!! ;-)
I have a flashing green power light and although I was able to begin the solution guru offered, I was unable to complete it because I do not have the controller for this tv. What are my options now?
Posted on May 28, 2010
  • Peter Rasmussen
    Peter Rasmussen Aug 11, 2014
    you dont need the remote. you can use the buttons on the side of the TV
  • Francesco Colotta
    Francesco Colotta Mar 12, 2015
    Thanks Antonio very much !, this worked for Me, Unplug the power Press menu and vol- plug in power release buttons!!
  • Sharp Master
  • 2,794 Answers
Chances are something was damaged in the power supply board and will need repair or replacement
Posted on Apr 24, 2018
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sharp Expert
  • 158 Answers
Hold down vol plus input and apply power on with remote
Posted on Sep 03, 2015
    New Friend:
I tried the volume - and channel + and it worked. Thank you veryyyyy much#
Posted on Jul 20, 2015
    New Friend:
Thanks Antonio very much !, this worked for Me, Unplug the power Press menu and vol- plug in power release buttons!! ;-)
Posted on Mar 12, 2015
SOURCE:
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
When I turn the tv on it came on for a minute then started flashing on and off then went blank but the power light keep flashing off and on with a blank screen.
This problem is easy to repair. If when you turned the tv on and it had sound and picture for a second or two, and the power went off and the power green light keeps flashing on and off, it is a bad CCFL backlight lamp inside the LCD panel which has 10 of these lamps in it, but only one is bad. Replace the lamp and the tv will power on. What the tv is doing is, it has stored a lamp error code on the main board and turning the power off. The replacement lamp is part # RLMPLA029WJN1 and you can buy them at www.encompassparts.com for $19.49 ea. Go to their web sight and sign in as guess to order. I can give you step to step instruction on how to check how many lamps you will have to order if you need me, too. You will have to take the tv apart to check them.
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
53,831 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
