Question about HP (5064-6630) Motherboard
No video out
I had to change my cpu, there is no video to monitors
  • 2,427 Answers
If you get a beep when you turn on the computer that means its working, multiple beeps indicate an error, no beeps at all mean that the processor is not initiliazing..
turn off computer and unplug it
1.) locate the jumper called or labled jp1
2.) its a 2 pin jumper and is currently set to 1 and 2
3) set it to 3 and 4
4.) set it back to 1 and 2
5.) try turning on the system
if you cant locate the jumper or yours is different what we are trying to achieve here is clearing the cmos. this can be done using the jumper or
1.) unplug your system
2.) remove the memory
3.) remove the battery
4.) press the power button 5 times to discharge the capicators
5.) replace batter
6.) replace memory
Try booting it now
if the above fails
try taking out your processor and putting it back in
if your mainboard has a clockspeed setting ensure it is set according to your porcessor clock speed (look at manual for details)
ensure you got all the necessary power cables connected
If you had the problem before you changed our processor then it night have been your mainboard that needs changing.
If you have a video card,ensure that the monitor is plugged into your videocard and not the onboard video the mainboard comes with.
Try your processor on another system to ensure its working, just cause it new doesnt mean it is good.
You can try clearing the cmos multiple times with the memory pluged in or without the memory to see if that helps
if all else fails then ensure you check the processor , only if the processor is good replace your main board..
Posted on Jan 06, 2008
8 months before my cpu was brakedown. that period i was not using this monitor. Today im connect new cpu and Now its displsying only quarter area of up side in the display. Other area ash colour look.
First, make sure you have the appropriate drivers for your monitor loaded on your computer. You may have to also change your video card settings to optimize the image.
Without knowing what make and model you are referring to, it is very difficult for the volunteer Fixya experts to focus in on the problem and then assist you.
Apr 21, 2015 | Computers & Internet
I have change my old CPU intel Celeron D 3.06Ghz to intel dual 2 core but my pc no display my pc is power on my monitor is power on also. The CPU fan is running slower then old CPU . My motherboard
is the monitor running through a vga connection? sounds to me like the mobo is bypassing the connection your using and sending your video signal elswhere. did you change any settings in the bios? try other video outputs to get the screen on then go into bios settings and change the video output to a connection your familiar with. help is here if you need it :)
Nov 20, 2012 | Computers & Internet
Samsung syncmaster793mb monitor displayed red colour
check the VGA cable from the monitor which is connected to the CPU move the cable fixed to the cpu back and forward and see whether the color is changing also check with another monitor it is to determine whether the fault is in with your graphics card or the monitor after changing the monitor if you still have the problem the problem is with the video session of the motherboard. to rectify add a add on graphics card to the port available like pci.agp or pci exp which is available in the motherboard
Oct 01, 2011 | Computers & Internet
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
My computer monitor changes from red to green and then somtimes it goes completly black. but when I reset the whole system its ok for a little while
try to connect another CPU on your monitor to check if your monitor running in good condition, if the display same problem,your monitor have a problem, you need to troubleshoot or as an assistant of a technician to repair your computer....if this monitor connect to another CPU is working, check your Video card if you have if none try to purchase a new video card because in your case the problem is video card adapter...
Mar 02, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Monitor will not display desktop, however, it does display have multi-colored vertical lines throughout.
You have eliminated the CPU/Video card as a problem so you should try changing the video cable.
There is a good chance that the cable is bad if the multi-colored lines you are describing is the "test pattern". So swap out the cable and see if that fixes it. If that doesn't fix the problem and the monitor won't work with another CPU, it looks like you are going to need a new monitor.
Jan 17, 2011 | Acer X221WSD Monitor
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
Samsung 150s monitor is changing background colors.
Connect your monitor to a different CPU to see the results. If it works, it's a video card problem. If you're comfortable, open your CPU case and remove / reinsert your video card. May need replacing. Good luck.
Jun 10, 2009 | Computers & Internet
Monitor works with one workstation but not another
OK; more basic troubleshooting is needed.
1] monitor doesn't work a] try on different cpu - check b] return with monitor from other cpu - ?
From the above I will try to spell out my steps.
1] notice monitor stops working
2] since I have another cpu close by - swap [it is important to also back swap {working monitor from other cpu]
analyze result.
I suspect that the video output somehow changed and the current display can't 'catch' what the video card is throwing.
does the display show the POST? is so, then you can start in safe mode and then set it to a low resolution.
Jul 21, 2008 | Computers & Internet
MOnitor Problem
Assuming the cpu is on, then the likely culprit is your video card or your onboard video. Either replace the exsisting video card or add a video card to your system.
Jun 16, 2008 | AcerView 76E Monitor
Computers & Internet Logo
76 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
