Question about Frigidaire PLMV169DC Microwave Oven
Turntable issues Hello, I'm clueless about fixing anything... the turntable on this thing is extremely noisy. sounds like a grinding sound. If it's a turntable motor problem, where can I find one to buy, and detailed instructions on how to replace? Thanks.
  • 45 Answers
As you say you are clueless about fixing anything, I suggest you take it to the service center and get it done. Replacing a electrical part has to be done properly, and fixing a turntable prob can be tricky.
Posted on Jan 06, 2008
Sharp sound bar buzzing
test this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
Makes grinding sound when turned on---does not heat---turntable does turn
Grinding sound may be the turntable not sitting properly on its support. Regarding the heat issue, check the door safety interlock switches for proper function.
As you use your oven, open the door while it is running, arcing occurs on the little contacts and they eventually burn. When they cannot make contact, the oven doesn't know if the door is closed or not. Forget what YOU know about the door ... the oven must know and it knows by the information it gets from these switches. Door open, the oven will not turn on the heat.
Thank yo for your interest in FixYa.com
Feb 22, 2010 | Goldstar MV-1501 Microwave Oven
Turntable won't turn
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
LG over the stove model lmvm 1935
In some cases, cleaning them helps. Lubrication is not recommended.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
My Sanyo microwave oven is six months old. The turntable has stopped rotating smoothly. Its motion has suddenly become jerky and noisy at the same time. I have given it to the vendor who sold it to me, for...
Since it's less than one year old, it should be fully covered under warranty, as long as the problem is not due to grease or liquid spilled down into the motor.
Nov 29, 2008 | Microwave Ovens
Lg lrm 1250 microwave
Some over the range models allow you to turn off the turntable via the keypad. Counter top models usually don't.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | LG LRM1250 Microwave Oven
Grinding noise/noisy turntable
Your turntable motor is probably failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to remove the bottom cover of the microwave (looking up from the stove top) and then the motor is accessible.
Mar 13, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave oven is noisy during use
Sounds like you have a failing turntable motor. You can contact LG / Goldstar about parts or service at 800-222-6457.
Apr 07, 2007 | Goldstar MA-790W Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
109 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
