Programming Remote Mitsubishi CS 13101
I have a Mitsubishi TV (older), Model CS-13101 and I need to program the remote to work. I found some remote codes but don't know what buttons to push on the remote to activate the codes. Thanks!!
SOURCE: Programming Remote
turn your tv on then hold the tv button down until all the little buttons on top begin to blink one at a time. it's about a 10 count. then the tv light will remain on while the light is on put in the code and the light will blink after the code is entered. if it is the right code your tv will turn off.
Posted on Sep 25, 2007
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Posted on Mar 29, 2008
Highdefjeff
  • 124 Answers
SOURCE: Need TV codes for programming a remote control
Here.
LG TV codes: 0178, 1265
Posted on Apr 09, 2008
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
I AM LOOKING FOR THE REVIEW ON THIS TV
Posted on May 15, 2008
I have a Mitsubishi cs-35505 tv. This model is an oldie, from '96, but still works... kind of. The remote is not really functional, even with new batteries and the internal speakers got turned off. I...
If you feel the remote is bad, you will need to find a new remote. The best option here is to find the MCM Electronics website. They will have a brand replacement. Thanks for asking and show a few hands of support!
Mar 21, 2011 | Mitsubishi CS-35405 TV
I need to program my remote, it is a ge universal and my mitsubishi is model cs-40505
Hello
Three digit universal remote codes for Mitsubihsi are:-
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Four digit universal remote code for Mitsubishi are:-
0005 0151 0051 0004 0009 0254 0022 0141 0180
Switch OFF and ON your TV with its front panel power switch, [NOT BY THE REMOTE HANSET] before trying each code
Proceedings
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 19, 2010 | Mitsubishi CS-40505 TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
May 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
May 09, 2008 | Mitsubishi CS-26201 TV
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Mitsubishi cs 27401
I CAN NOT PROGRAM MY MITSUBISHI TV MODEL CS 27401. I HAVE THE REMOTE BUY IT HAS TOO MANY CODES THAT I CAN NOT HANDLE.
THANKS,
CLAYTON77
Dec 06, 2007 | Mitsubishi WS-65515 65" TV
Mitsubishi tv model no. CS-2567R
I had no luck finding anything for this model number even on the Mitsubishi site. How old is this set?
I would try programming the remote to some alternate codes for Mitsubishi products. It sounds like it's not programmed correctly. If you don't have the codes I would search the web for your brand of universal remote to see if you can find it's instructions. Lastly, on the topic of the remote, most universal remotes have a method to program even when you don't know the codes. This usually involves turning on the TV then putting the remote into a specific mode and hitting the power button until the TV shuts off.
How are you connecting the dvd/vcr? Are you using a single coaxial cable (the kind with the threaded connector) or are you using composite cables (yellow, red, and white plugs) or some other type of cable? If you're using the coaxial cable then you will typically find the signal on channel 3 or 4 on the TV when the source is set to tuner. If you're using one of the other methods then you will need to find a button on the set labled something like "Video Source" or "TV/Video". If you hit that button the TV will switch through it's input sources. It's very possible that this feature will not be available on your Universal remote even if it's programmed properly. You may have to select the source on the TV itself.
Good luck and let me know if any of this helps.
Nov 27, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
