Using a volt/ohm meter check the thermal fuse on the top left side of the heater canister for continuity. If no continuity replace the thermal fuse and the hi limit thermostat on the bottom of the heater canister. These parts come as a set. If I had a model number i could be more specific.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Estate TAWS750PQ
Whirlpool Estate TAWS750PQ 27-Inch Super Capacity Washer in...
i just purchased a used whirlpool estate washer. Model # TAWS700RQ1. I transported it on its side...
(More)
i just purchased a used whirlpool estate washer. Model # TAWS700RQ1. I transported it on its side not realizing this could effect it. Well, the spin cycle does not seem to be working, the close are soaking wet and I think it barely spins if at all. What happened and How I can fix this?
dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is...
(More)
dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is less than a year old and we clean the filter after every load. checked the vent hose and its clear with no crimps.
drying very slow. replaced timing thermostat,thermal fuse and ignitor. Ignitor goes on and off with...
(More)
drying very slow. replaced timing thermostat,thermal fuse and ignitor. Ignitor goes on and off with no gas after intial heating.
