Question about Garmin Quest GPS Receiver
Quest GPS stopped turn on after 4 years of perfect working
This happened suddenly. My device was connected, as usually, in my car through its power cable. I turned on the ignition key but the screen didn’t get the usual Welcome Message. I thought the red small power button was off; I switched it on/off several times. Nothing happened. I tried to power it up, outside the car, from its power adapter with regular AC plug. Again the screen didn't light up.
I believe could be an internal component of DC power circuitry or the power small red switch broken. Do you advice to open up the box (6 screws) and watch inside? What else should I do?
NOTE: My QUEST worked fine for at least 4 years.
Thank you,
Vladimir
  • 1 more comment
  • Vladimir Dumitrescu Jan 06, 2008
    I found the solution myself reading the User Manual (If you Quest Lock up..)
    Actually the unit locked-up. According to the manual, I reset the unit by pressing the power button and IN button at the same time. The unit turned off. I turned it on again and now it's working.
    Vladimir
  • Anonymous Feb 14, 2008
    First mine did not turn on in the car at all.
    I plugged connected the unit using the AC adapter and after a few minutes it came on by itself. I disovered that after I turned it off it would not turn on using the batteries alone. I plugged it back in fiddled with the On, OK and speaker buttons ror a while and and turned it back on. But I found no reliable way to turn it on.
    The next day it failed in the car after about 15minutes.
    I disconnected from the car, and started it on batteries. Once I got it started again pushed the power button and in at the same time this seemed to fix the problem. It has been working fine for 3 days now.
    I would cure a problem of the unit not powering up as follows:
    1. Start the unit on AC power, (per Garmin support)
    2. If the unit does not start after a few minutes fiddle with power OK and speaker buttons.
    3. Once the unit does start reset by pressing power and in at the same time. (Per the user manual)
    4. As an added precation I cleared the track log, I do not know if that did anything.
  • Anonymous Jun 05, 2008
    Vil, Thank you for the info. It worked the treat. Very grateful to you.
    Esther.
Thank you! Thank you!! Thank you!!!
I, too, have had my Quest for about 4 years (got it the week they became available) and I love it. Was worried that it was toast.
Your solution has it running again.
Did I say thank you? Thank you!
Posted on Jun 21, 2008
Dude
Thank you, sorted my problem out too..
Posted on Mar 24, 2008
Vladimer's solution worked for me too. Hooray! Many thanks!
Posted on Feb 12, 2008
My TomTom,VIA 280 has suddenly stopped working. It is barely 2 years old. It will not power up
let it sit on the charger over night, check the charger on another device too.
Dec 08, 2014 | Tomtom GPS
Tomtom GPS does not turn on
HELLO!!
Charger gets very hot means the problem lies with charger which is not supplying the power to the system ... Try changing the charger ... and the charger wont cost u more than 15$
CLICK HERE TO BUY
GUD LUCK!!!
Dec 27, 2007 | Tomtom ONE GPS Receiver
All of a sudden, my Go 920 screen calibration is way out of sync, enough so that I can't select any buttons accurately. I have restored, reformatted, etc, but I can't even select the language...
Well, I can say this from a guy that has had several gps, in most cases Tom Tom is considered the low budget of the gps devices out there. If your lucky when you buy them and they work, feel lucky. They are considered disposable gps systems. I went through a few myself, until I ended up getting a megellian and works perfect, mor goodies, and never a problem in the last 4 years I h?ve had it. My advice, don't bother trying to fix it, because in a few months will happen again. Thanks Mike ( x truck driver)
Jun 09, 2011 | Tomtom GO 920 GPS Receiver
My garmin quest will not come on even when powered by the car cradle. It flickers for a brief second, then fails.
This sounds like an old battery that has deteriorated to the point where the external power won't even turn the unit on. I have a fairly detailed description on FixYa of how to replace the Quest battery. Search for something like Quest Battery. It does involve opening the unit up. If you are not comfortable with the inner workings of electronic equipment, you will need to return it to Garmin.
Apr 06, 2010 | Garmin Quest GPS Receiver
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
poky345@yahoo.com
Can not seem to find any reason?
Mar 31, 2010 | Garmin nuvi 1200 Car GPS Receiver
Voice stopped working suddenly
Sounds to me ethier the mute is on and not showing or the speaker is out
Aug 30, 2009 | Tomtom ONE 3rd Edition GPS
Quest Battery
A battery for a Sony Clie N610C works perfectly, everything fits and its easy work to do. Just cut the leads off of your old battery and then solder them to the Clie battery (its on a little circuit board) and then install, my Quest II now has a functioning battery 15 minutes later.
Apr 18, 2008 | Garmin Quest GPS Receiver
Stops working when unplugged
Check the auto turn off settings, could be a power interuption
Jan 07, 2008 | Garmin Quest GPS Receiver
Charging
"unit turns on and off with the ignition switch, sometimes."
There is something wrong with your power cord or the connection to the cigarette lighter. Your unit should turn on and off with the ignition switch. If the unit is on and doesn't turn off with the ignition switch then your unit is running on battery. If your unit doesn't turn on with the ignition switch then the unit is not getting power from the cigarette lighter.
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
No Voice / Sound
Put your mouth over the speaker & blow gently, if the diapgragm in the speaker is faulty (probably) this may lodge it back into position. Try it, nothing to loose.
May 29, 2007 | Tomtom ONE GPS Receiver
Garmin Quest GPS Receiver Logo
128 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
