Question about Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
Does not respond
After i flip the bluetooth on a purple light is steady for about 3 seconds and disappears and my phone does not recognize it. How do i fix this problem
  • Anonymous Feb 12, 2008
    I use to answer & hang up from the H550, and even voice dialing, but now nothing is happening!!! how can I fix it?
  • zackmo80 Jun 25, 2008
    when i switch my bluetooth to on nothing happens
Je veus savoir si le H550 est compatible avec un cellulaire samsung
Posted on Feb 15, 2008
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
How do i put a motorola h700 bluetooth into discovery mode
close the mic and push down the button until the light shows purple. Flip open the mic and it should be steady purple. it's now in discovery mode and you should be able to sync it to you phone.
Feb 14, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700C - purple light
its on paring mode that means that its ready to be pared up with the phone.i would just close it to turn it off and reopen it and connect
Jul 17, 2008 | Motorola Mobility H700 Wireless Headset
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Power won't come on
I am having similar issues. Before you OPEN the boom, press and hold the CALL button in the middle and ensure your Bluetooth is paired/synced with your cell phone.
Press and HOLD about 5 seconds until the PURPLE light illuminates. Then flip it open immediately and begin the pairing process.
My problem is that the purple light won't illuminate at all...
good luck
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Purple light on H700 will not stay lit
I was having trouble with the same thing. The light would flash purple when closed, I opened and it stayed lit only for a second. Give it another second, I found it flashed off then came back on steady for pairing mode.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Jun 24, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset Logo
66 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
