Home | Bosch | 24 in. SHU43 Built-in Dishwasher | There is water at the...
Bosch 24 in. SHU43 Built-in Dishwasher
Problem for Bosch 24 in. SHU43 Built-in Dishwasher
There is water at the bottom of the diswasher.
By ndaugusta on Nov 08, 2009
There is water at the bottom of the diswasher. How can I drain this or what should I look for to fix it
Best Solution
posted on Nov 08, 2009
Very Helpful)
rylee_smith
Rank: Guru  Dishwashers  Expert
Rating: 87%, 953 votes
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch 24 in. SHU43 Built-in
Questions and Unsolved Problems for Bosch 24 in. SHU43 Built-in
Do you recommend Bosch 24 in. SHU43 Built-in Dishwasher?
Answer
Answer
We recently bought an Integra Bosch dishwasher. It cleans well. However during the drain cycle there... (More)
Answer
I swicth the dishwasher on it lights up, starts the cycle and then stops after a few seconds, have... (More)
Answer
Replace front panel with stainless steel . It is an older model, SHU4300
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU43 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
