Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 blink the light on delay dosn`t works no botton
The washer work good untile cycle miss17minute and the washer blink the light of delay and felt the cycle and i push all botton dosn`t to do eniting.
  • 1,294 Answers
Press "end of cycle" button to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore Elite washing mahcine HE3 quietpak2 Model#110.45862404 - The selecting cycle wash button does not follow command. It is only delicte and handwash cycle wash botton is working.
Sounds like a problem in the button panel, but could be firmware is in a knot, which is an easy fix: Try unplugging machine and plug back in 5 minutes later. Then see if it works.
Jun 19, 2015 | Kenmore HE2 Plus Front Load Washer
The washer works fine until it gets to the last rinse cycle. The rinse light blinks and the washer cuts off.
Will make a guess. Machines can stop on the last rinse because it is waiting for the fabric softener or because it is on a delay and leaves the clothes floating so they do not crease awaiting an action to say carry on.
Jan 21, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 starts by itself in "delicate" was cycle and fills with water when not in use. Can all this be caused by a bad selonoid??
Check that the machine is not on an auto delayed start. Strange that it starts itself. If a solenoid fails, 2 things happen. They either don't let water in at all, or they don't stop letting water in. If its not on an auto delayed start, I suggest that it could be a faulty main control board . You can stop the machine by turning the water off and switching the machine off at the socket when not in use.
Dec 24, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer does not start
Are you hitting the start because it sounds like its pausing ,waiting for you to start it.
May 20, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
112 people viewed this question
Sal De
 Brian Main
Brian Main
