Home | Dell | "Inspiron 2200" PC Notebook | Blue Screen saying Unm...
Dell "Inspiron 2200" PC Notebook
Problem for Dell "Inspiron 2200" PC Notebook
Blue Screen saying Unmountable_Boot_Problem\r\nI
By laureen384 on Nov 08, 2009
Blue Screen saying Unmountable_Boot_Problem I can't even restart in safe mode.
Solution #1
posted on Nov 08, 2009
Not Rated)
C0MPUTERGIRL
Rank: Guru
Rating: 89%, 19 votes
You most likely have a corruption issue but sometimes it is a bad drive causing the corruption.
Get a windows XP disk and start up in Recovery.
Make sure that the system is set to boot from CD. You can do this in the BIOS or on some systems you can do this from the Boot up screen (you will see a function key for boot device selection)
When you get to the Setup Welcome Screen press R for recovery console.
1. chkdsk /r ENTER (dont forget space /r and it takes some time to finish. Just be patiient)
2. chkdsk /p ENTER
3. fixboot c: ENTER (where C is the boot Hard disk).
If this doesn't work and a repair or fresh install does not help then you will need to replace the Hard Drive.
Hope you get it back up withought losing any data.
Another option is to remove the hard drive, get a converter and hook it to another machine, pull data then run your repair after that.
Was this helpful?
Yes
No
Solution #2
Not Rated)
parrotheadpc
Rank: Guru  Dell Computer Hardware  Expert
Rating: 89%, 536 votes
When booting up to Win XP you may get a error that reads "Unmountable Boot Volume". This is probably because your boot.ini file is messed up. Boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows If for some reason that don't work for you, you can boot to the recovery console like above and...
Type "chkdsk /r" then enter
When done type "exit" and hit enter.
This will take longer, but the system should boot back into Windows.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Benimur
Rating: 88%, 3768 votes
Hi and welcome to FixYa,
Almost always, your describe problem would indicate hard drive problem. This could either be:
  • corrupted files (least likely);
  • some bad sectors (likely);
  • faulty hard drive (most likely).
To check / verify, remove the hard drive, connect to an IDE / SATA to USB adapter and perform drive utilities on a 2nd computer.
Alternately, you could try formatting and reinstalling the Operating System. This of course would delete all the contents of the hard drive.
Was this helpful?
Yes
No
Popular Solutions for Dell "Inspiron 2200" PC
Questions and Unsolved Problems for Dell "Inspiron 2200" PC
Do you recommend Dell "Inspiron 2200" PC Notebook?
Answer
Answer
when i turn my laptop on it works as normall then i just get this black screen with no icons in... (More)
Answer
I have this aspire notebook and it is only 2 months old. For some reason, the speakers are very... (More)
Answer
on warhammer 40k dawn of war 2 i put the install code and it says an error i looked everywhere and i... (More)
Answer
Se ha sobrepasado la cacidad del puerto concentrador
Answer
no sound thru hi fifrom headphone sockett
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell "Inspiron 2200" PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
