Question about Engel Commercial Refrigerator
60 ltr engel
Hi my 60 ltr engel isnt getting cold any more it sonds like the compressor is cutting in and out like its got a tight spot in it the fridge is about 9 years old and has been well looked after.I was just wondering what a solution would be to fix it thanks craig
  • 4793 Answers
SOURCE: engel 43 qt fridge freezer stopped cooling.
have you checked the compressorpump is getting warm(a sure sign its working.sometimes a little tap works)
Posted on Feb 11, 2010
0 characters
1 Points
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
have u checked the groumets on the compressor? more than like are bad
Apr 20, 2015 | Engel Refrigerators
My 47 ltr fridge is reading 60 Celsius on 12 volt but -2 on 240
That is because it is using a compressor for 240 and and an adsorption or peltair process for 12 Volts.
Mar 03, 2015 | Refrigerators
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
At first i smelt a burning smell then found the fuse had blown,i replaced the fuse and worked for a while then the motor was geting hot and the fridge wouldnt stay cold
it means your compressor hi pressure cause of blown fuse check the condenser fan if running ok if not replace capacitor or lubricate main shaft. then observe your comp. if working continues.
Feb 19, 2011 | Engel 43 Qt.Portable Freezer.
My fridge isnt getting cold
if the fridge isnt getting cold, and the compressor is running, try to check the amperage of the compressor side, if the amp. lower than normal current, there must be a problem of the refrigerant (leaking) or lose compression. And if the compressor is not running try to check the thermostat, compressor and the relay.
Dec 05, 2010 | Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on
Nov 03, 2010 | Bosch Refrigerators
I have a kenmore cold spot refriderator not cooling
Since the compressor is not hot to touch, I would bet that the relay /overload assemby on the compressor terminals are defective.This is a common problem on refrigerators that can be fixed with a few simple tools. I recommend a 3 in 1 start kit that is easy to retrofit. Start by removing cover off compressor. Read intructions on kit to hook up three wires to terminal s,r, and c. Next cut the black wire feeding power to compressor and hook to one line of kit. Cut white common wire and hook to other line of kit. Place the kit off to the side of compressor and reinstall the cover. Plug frig back up and compressor should run if installation is correct. Hope this helps
May 17, 2010 | Kenmore Refrigerators
Engel 43 qt fridge freezer stopped cooling. the compressor comes on, the fan is blowing but not cooling
Feb 11, 2010 | Engel 43 Qt.Portable Freezer.
35 litre Engel. Not getting cold.
can you feel if the fan is blowing air
Jan 21, 2008 | Refrigerators
Engel Commercial Refrigerator Logo
35 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
Sudeep Chatterjee
Sudeep Chatterjee
John Tripp
John Tripp
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
