Question about Intel D845GVSR Motherboard
Motherboard taken out by eMachines Bestec power supply
Does anyone know exactly which components on the motherboard are blasted by the infamous eMachines/Bestec 250W power supply when it fails? Is there any hope of a component level repair for this motherboard? I repaired XT and AT motherboards a LONG time ago, way back when chips had pins that went all the way thru the board...
  • 4 more comments
  • frusto Jan 06, 2008
    Yes, but it didn't work. I actually have two identical eMachines T2862s, one of which didn't boot, the other *was* my only working desktop. I had tested the non-booting machines PSU by jumpering the power on pin to ground, and all voltages were normal, so I took a deep breath and connected it to my good machine, plugged it in, and...nothing. My formerly working mobo is now toast. After destroying it, I googled "bestec power supply fail emachines motherboard" and found that everyone knows that the Bestec 250W supply kills the mobo when it fails, to the point that some are contemplating a class action suit. Wish I'd thought of that before making the fatal connection. Thus, I was wondering if anyone out there knew what got scorched on the mobo. No visible or audible damage.
  • Anonymous Mar 14, 2008
    Same problem with power supply taking out M.B.. I have a few of these boards and just can't seem to locate the failed fuse if a fuseat all.
  • DUCKY711 May 23, 2008
    eMac T2862 mother board dead from PS failure. Has anyone found a easy fix? I am going to replace the PS and Mother board. Does anyone have suggestions on what mother board would be best (for $)?
    THANKS
  • Anonymous Jun 23, 2008
    What do you mean by "tested the non-booting machines PSU by jumpering the power on pin to ground"? Can you describe this method, because I have the same problem as you and I need to test the power supply.
  • mypoodlepals Jul 26, 2008
    I pushed the power button and nothing happens. Replaced the power supply same problem. What do i do now?
  • rahimsheikh Dec 16, 2008
    Bestec power supply not coming on, but comes on when I disconnect the mobo cable. Green light at back of power supply is flashing green 2 x per sec. When I groud the PSU (by connect green wire to black), the fan comes ona nd the green led is solid. No burn marks ont he mobo....Help!!!
I have not identified the specific components on the motherboard that blow, but I can tell you the defect in the Bestec supply. The +5 VSB, which is the voltage that is on at all times, loses regulation and climbs to 8-11 volts. I believe this "higher than the required" +5V takes out the components on the motherboard involved with the computer/power supply "turn-on" circuitry. The "on" button on the eMachines front panel no longer turns the motherboard on because the "kept alive when the main power is off circuits" - which allow the on/off button to do its job of turning on the machine - no longer work.
Test your Bestec power supply by plugging it in the wall socket and have it not connected to anything. Read the voltage between the purple wire and any black wire. If you see +5.0V, then this wasn't your problem. If, like it did on mine, is closer to between 8, and 11 V, this is what took out the motherboard.
Posted on Oct 08, 2009
To "test' the power supply; remove the 4-Pin power connector, and the 20-Pin ATX power connector. Jumper the Green Wire (power supply enable) to a Black Ground Wire (there are several to choose from, just pick one). The fan on the power supply should spin up, and you should be able to test the voltage outputs at that point.
Posted on Jul 04, 2008
Im having the same problem...new power supply and no boot but motherboard liight comes on anyone find out what the problem is
Posted on Jan 15, 2008
See my Hot Swap solution in title Power Green Light Flashing HP Desk Top PC m7250n
Posted on Sep 19, 2008
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Check it with another power supply, and assure it's propietary. Also check the capacitors on the motherboard, you may need to recapp them.
Posted on Jan 10, 2008
    Genius:
  • 1,067 Answers
Did u try new power did it work maby none
Posted on Jan 06, 2008
  • 1 more comment
  • nick helpap
    nick helpap Jan 06, 2008
    power switch in front bad try using a new switch maby wire in reset switch to the power on 2 pin on mobo test your switch on those k
  • nick helpap
    do u know what i meen reset switch stick it on the power on 2 pin unplug the 2 pin main switch thats in it to test see if yuor switch is bad
  • nick helpap
    also is your bios 3 pin cmos clear in the 1 and 2 pin not on 3 if its on 2 and 3 wont boot ok
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
109
Posted on Mar 13, 2009
My computer shuts down
problem with you either capacitors on motherboard or capasitors in smps, 80 % it becouse of capacitors in smps, it's not providing sufficient power to motherboard.
Feb 26, 2011 | E-Machines eMachines Desktop PC
Emachines E4252 shutting down on boot up
This could easily be a power problem. You can check for overheating, but I would recommend not attempting to turn on the computer again, until you test the power supply.
eMachines (and gateway) have a long history of using Bestec Power Supplies (recognizable for their bright yellow warning label). These are highly defective and can result in the frying of your motherboard and/or processor.
I would recommend checking what kind of power supply you have. If it is a Bestec, it is most likely defective (or will become defective soon). Based solely on that, I would replace it. In addition, it may have already damaged your processor (causing it to get too hot easily) or your motherboard. Its rough, but better you fix it now, as opposed to replacing the motherboard or processor, just to have the power supply fry the new one (the Bestec PSUs still look like they function when they have failed, but send completely unreliable volts to your board).
If you need assistance finding new parts, I can direct you to cost effective alternatives.
May 09, 2010 | Gateway Computers & Internet
I'm trying to "rebuild" an old desktop computer of mine just to play and learn new things. It's an Emachines T2625 . Everything is in working order, but the integrated video seems to have went bad... I...
just start over and buy a motherboard and processor and memory and plug your stuff into it. you will need an operating system because the emachines operating system only workes with an emachines motherboard. emachines is the cheap brand from gateway and i have had nothing but trouble with those machines. Hope this helps and good luck
May 02, 2010 | E-Machines eMachines Desktop PC
I have an emachine t5026 that won't turn on. It sounds like a car tying to start and the lights on the front flash as does the light on the mouse, but it won't start.
Mar 29, 2010 | E-Machines Emachine T5026 power supply **...
Power suply the computer wont turn on
the smos of the comp might have gone bad
Feb 07, 2010 | E-Machines eMachines Desktop PC
I have an emachine model 3220. The bestec atx power supply has a part rattling round in it. Is it worth me buying a new power supply and if so other than bestec (as I have read bad reports on this item)...
When you say you have no power at all to your computer, have you checked the motherboard to see if you have a green light that comes on? You have to take the cover off and look at the motherboard. If the light does come on, it isn't your power supply. It is the motherboard. Good luck!
Nov 16, 2008 | Computers & Internet
Power buttone notworking for Emachine T3624
Power problems are not always the power supply. A small amount of power is sent to the mobo to perform self test, and if the computer is ready, it signals the supply to turn on the rest of the power. That's to prevent a small problem from cascading into a large one. But it is difficult to troubleshoot. The problem could be with the mobo or the CPU. That's why you need to find a reliable repair shop with people who know what they are doing...not someone who only knows how to swap parts and calls that "troubleshooting."
Oct 02, 2007 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Intel D845GVSR Motherboard Logo
2,369 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
