i have a mac and the software was installed fine. But when i turn the printer on, it feeds through paper and then stops with quite an alarming sound. I then have to press cancel twice in order to get the rest of the paper through. In the mean time the paper button constantly flashes??? Also when you open the printer, should the ink cartridges slide to the middle, as i don't see where you should them in?
First thing you need to do Turn off the printer and Open the rear access door or cleanout area as we call that (back door) and clean all the rollers on the back. make sure also that you are using the deskjet paper and if you put 20 pages of paper on the paper tray make sure to fan it before you put it in. the alarming sounds or blinking on the printer indicates that the paper is jamming on the printer
-The ink is normal to move to center or left to right, But if you open the printer access door the ink or the printhead should stay on the middle for you to able to replace the ink cartridges and remove the printhead
My ESP 3 printer seems to use up the color ink alot faster than I expected since we don't use color...
(More)
My ESP 3 printer seems to use up the color ink alot faster than I expected since we don't use color that much. Is there a proper way to clean the heads? The words being printed are stating to come out blurry. Help. Pete
I have an all in one esp-3 4x6" paper got jammed, I took off rear and removed paper can not...
(More)
I have an all in one esp-3 4x6" paper got jammed, I took off rear and removed paper can not figure out how to reconnect rear panel
Paper runs through the printer, but nothing prints. I've changed the ink. How do I reset the...
(More)
Paper runs through the printer, but nothing prints. I've changed the ink. How do I reset the printer?
