Question about Haier HSB03 Compact Refrigerator
Will not cool
It will not cool at all. I came home after a vacation to find the fridge at room temp. I unplugged it for a while and it will not do anything when I plug it back in. The LG compressor in the back will get really hot when I plug it in now. Anyone know what the deal is? Thanls
  • 1 more comment
  • tollfree969 May 21, 2008
    It it worth getting repaired of should I just toss it? It is only a year old so it kind of sucks...
  • eloffredo Jan 18, 2009
    same deal. woke up one day, and found the fridge warm. Compressor is warm. Tried leaving it unplugged for 12 hours, then restarting it - no luck
  • Anonymous Feb 15, 2009
    I have the same problem, and my refrigerator is just over a year old
  • 57 Answers
If the compressor is getting really hot it's more than likely SHOT.
There is a small possibility you have a bad overload/start relay.
But compressors do not like getting hot.
Posted on May 21, 2008
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
Amana Model SZD25NL is not cooling at all, neither
compresor fan working? if it is not you need to consider the compressor starter need to be replace
Dec 29, 2009 | Refrigerators
Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Aug 09, 2009 | Refrigerators
Neither refrigerator nor freezer cooling.
sounds like the compressor or relay went out. if the compressor is hot turn off and let cool to room temp. and try it then [a few hours] , if it is not hot then replace the relay on the compressor.
Jun 10, 2009 | Kenmore 52582 / 52584
Norcold fridge not cool enough
Yes very likely the cooling unit has stopped working. You need to do a bypass test by unplugging the thermistor on the inside of fridge. It will be attached to the fins. Give it 6 hours or so and check your temps. If they are the same the cooling unit is bad. If the temp goes down the thermistor or circuit board is bad. If you need more assistance feel free to call.
734 777 6432
Jan 25, 2009 | Refrigerators
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
My ge side by side not cooling, freezer act like fridge
Sounds as tho your compressor is bad if it is still under warrenty take it to the place of purchase.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Sep 05, 2007 | Maytag MSD2454G Side by Side Refrigerator
Haier HSB03 Compact Refrigerator Logo
472 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
