You will need a coffee can, clear hose that fits snugly over the bleeder screw and a 3/8 or 7/16 open end wrench. Find the bleeder screw on the oil pump. It will look like a grease fitting or brake line bleeder screw. Put the clear hose on and put the open end in the coffee can. Start the burner by making sure the door switch is closed and the red reset button is depressed. As the furnace starts, open the bleeder screw and watch the pink fuel as it goes into the can. Your primary control will trip after a few seconds (15-45). Close the bleeder. Reset the primary control, you may need to let the control sit for a minute or you may need to hold the button down for a minute to reset the control (each control is different). Then start the furnace and open the bleeder. You are looking for a good flow of oil with no bubbles. If you do this more than 3 times, you have an air leak in the suction line somewhere or low oil level.
I'm getting a 35000 btu natural gas wall heater to replace an old one install in the hallway if my...
(More)
I'm getting a 35000 btu natural gas wall heater to replace an old one install in the hallway if my 900 square foot house. Any opinions on whether I should go with a gravity or counter flow model? Priced out central heat but too expensive!
My Kenwood model # TRN0812tk portable heater is 4 months old, worked great and now, nothing. Should...
(More)
My Kenwood model # TRN0812tk portable heater is 4 months old, worked great and now, nothing. Should I junk it or is there anything I can check to fix it?
Have a Broan,Nutone 9194NT wall heater,3000watt,240 volt.After running about 20 min.it over heats...
(More)
Have a Broan,Nutone 9194NT wall heater,3000watt,240 volt.After running about 20 min.it over heats and the fan stops.Does anyone else have this problem?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
