Whirlpool Duet GHW9150P Front Load Washer
Problem for Whirlpool Duet GHW9150P Front Load Washer
CODE DL Failure
By marcyfcook on Nov 08, 2009
CODE DL Failure
Solution #1
posted on Nov 08, 2009
Not Rated)
rbhomesource
Rank: Guru
Rating: 86%, 28 votes
door latch failure. If your crafty you can replace it yourself, there are several places online to buy parts. To get it out unplug the machine, Take the outer ring off the door gasket, roll the gasket back, and unscrew the two screws holding the door latch to the machine. Replace!
Comments:
Nov 08, 2009
- if the door wont unlock to get at the latch, take the bottom panel off with the 3 screws along the very bottom of the machine. You can pull on a manual release that is at the bottom of the door latch.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
Questions and Unsolved Problems for Whirlpool Duet GHW9150P Front
Do you recommend Whirlpool Duet GHW9150P Front Load Washer?
Answer
Answer
my washer will not compleat a wash cycle it stops and sud flashes and want drain what can i do
Answer
turned it on to run wash. didn't realize the water wasn't turned on. now the pump won't turn off.
Answer
When washer is not in use it partially fills with water.
Answer
wgd9400 whirlpool: we need the instructions/manual on how to direct vent from the bottom of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Duet GHW9150P Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
