Question about Dell Dimension 5100 (D51L1) PC Desktop
Will not turn on.
We had a power outage and our computer is connected to a surge protector. It will not turn on, I have tried different cords, different outlets. I switched the red breaker switch in the back and have tried to turn it on, it will not work. The motherboard has a green light on so it is getting power. (This happened once in july of this year, after a power outage. I took it to a it tech at my work and he said he plugged it in and it turned on. afterward it just worked)
I am not sure if it is the on/off button, I inspected it from the outside and could not see anything wrong with it. I smell no burnt smell coming from anywhere in the computer. Please help
Josh
  • Anonymous Jan 10, 2008
    My son had exactly the same problem last week and the machine still will not power up. Were you able to find any further information about the cause?
    Genius:
  • 1,067 Answers
Bad power supply chang epower strip use monsyter clean power one clean up usa dirty power dont ever flip that switch in back to 215 u will fry it we use 120 115 in usa only ok
Posted on Jan 06, 2008
Why won't it start?
The computer is not producing a video signal.
The varistors in the surge protector are probably burned out, or there is some other problem in the surge protector.
The monitor is very likely OK.
Jul 25, 2015 | LG Computers & Internet
Zenith Pdp42t10000 won't turn on after power outage..it was on a surge protector which was still plugged in but was in "off" mode.
Connect something else to the same surge protector, and turn that on. Does that work? if not replace the surge protector.
Dec 19, 2013 | Televison & Video
My Power Edge is not starting. On the power supply there are no LEDs whatsoever lit. The cord is OK TO the supply since I have tried it. The server is stone dead and does not start. What is wrong?
In most cases like this, if there are no lights on the back of the power supplies, (i assume there are 2, as I have a 2950 and it has 2) that they are dead, and need to be replaced. If you haven't tried it already try this: 1. Swap out power cords, try different ones. 2. Swap out surge protector if you are using one. 3. Switch wall outlets that the surge protector or power cord is plugged into. If none of that helps then you can safely assume the power supplies are dead. Did you have any power outage or surges lately that you know of?
Jul 01, 2011 | Dell POWEREDGE 2900 Server
I have a Cyber-Power 425 VA and I think it has been tripped by a power outage recently. I was able to get my computer & monitor working again by removing them from the surge protector and plugging them...
Probably should be tossed. But you can try plugging a standard lamp into it. If it powers your good on that aspect but no way to know if surge pretection is still valid.
Mar 14, 2010 | Computers & Internet
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
My printer won't turn on after a power failure.
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
Dec 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:-shahworld_2998@yahoo.co.in
May 05, 2008 | Compaq Presario S6300NX PC Desktop
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
155 people viewed this question
Alun Cox
