Question about Canon S400 InkJet Printer
Canon s400 doesnt print only blinks eight times
Our canon s400 doesnt print but only blinks as I remember eight times. I read somewhere in the manual that when it blinks that number its waste tank ink is full. we don't really know if that is the case.
  • claseaparte Mar 21, 2008
    The light is bliking and the printer don't stay online.
  • Anonymous Nov 28, 2008
    light blinks and does not print
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Posted on Nov 27, 2008
    Scholar:
  • 48 Answers
Refer to the manual or online to find out how to properly execute the waste tank procedure. Also the manual should tell you how to reset the code
 after you clean the tank. The tank is located on the bottom, it is a
 felt pad that you have to rinse out. There is lots of ink involved so
 it can get messy.
Posted on Jan 06, 2008
Printing of canon s400 poor quality on my computer but prrint fine on other computer
under printer driver properties on your computer,under print preferences, check the print quality settings. i.e if the quality is set to draft change to high.
Aug 23, 2011 | Canon S400 InkJet Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I just replaced the cartridges on my canon s400 printer and now it doesn't want to print. What could I do to fix the problem?
Hello thhe fix for this is
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 15, 2009 | Canon S400 InkJet Printer
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
Jun 18, 2009 | Canon S400 InkJet Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Soon after initiating printing, Canon s400 printer stops with a loud clunk. This produces Error 5100. Turning off and on again does not help.
Hi You can Try
Error Code 5100 This happens lots in caon
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Apr 13, 2009 | Canon S400 InkJet Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
Canon S450
From what I can tell the 6 orange lights indicate a print head failure. Why the print head has failed is another question maybe too old (I've read somewhere that they only operate for a fixed amount of time), maybe printed enough pages (somewhere else indicated that they only print a fixed number of pages). The solution is to replace the printhead (not just the ink tanks).
There is no way to know which print head needs replacing, so unless you have a spare one you will just have to choose which to change, and if you get it wrong try the other one. It appears to be an expensive way of solving the problem (but I have just found it cheaper to buy a print head which comes with 3 tanks than to buy 3 separate tanks!).
Paul
Nov 19, 2008 | Canon BJC S450 InkJet Printer
Canon S400 problem
The little internal button battery that keeps track of time is going dead. Canon will fix this for free on your model camera regardless of warranty status. Here's the link to the info:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Mar 14, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Canon S400 InkJet Printer Logo
404 people viewed this question
old marine
old marine
