Question about GE Profile Spectra JGBP90 Gas Kitchen Range
F7 and SF codes on GE XL44
Hi, this is the second panel we have had to replace on our gas range. After plugging the power in, the panel starts beeping with a F7 code. We tried to reset the codes using the solutions offered on the web. For example holding bake and self clean. Nothing works. Do you have any suggestions?
  • Craigbur Nov 04, 2008
    F7 code and beeping constantly especially once the broiler is being used - seems to be caused by excessive heat at the back riser of the range. Now does it randomly even when the stove is not in use.
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
BNewberry
Bill Newberry
  • 93 Answers
SOURCE: Code F7 on my GE Spectra XL44
http://www.fixya.com/support/t120458-ge_profile_oven_ftp18_f7_code
Try reading this and see if it helps you any, thank you
Posted on May 16, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
tom weber
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: [email protected] I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Gas Range just started beeping and has F-1 on the screen. How do I get it to stop beeping?
Hi ......A f1 code indicate a stuck or faulty touch pad or button?Sometimes moisture or a spill will cause this problem,Unplug 12 -24 hrs and reset.If this does not cure your problem turn off power unplug touch pad from control board and turn back on. F1 still there? If yes replace control board if not replace touch pad.If components are not separate electronic control will have to be replace, Hope this helps .Please rate my answer/response :)
Dec 13, 2009 | GE JGBP24 Gas Kitchen Range
GE profile XL44 code F7 & FO readng on
Turn the circuit breaker off at the switchboard for a minute then back on again. This may reset the electronics.
Nov 22, 2009 | GE Kitchen Ranges
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
GE SPECTRA GAS RANGE XL 44 BEEPS AND DISPLAY F7
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
Control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
62 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
