the water does not get pumped out of my hoover performer washing machine. Is there a filter that can be checked? I thing it is at the bottom but cant seem to open it.
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Comments:
Nov 08, 2009
- If `the fault occurs again, you must remove the filter to check it is clear.
Cheers.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Thank you so much and vert helpful. Found the filter and undid screw, but the knob couldn't be turned. However the fault seems to have gone away.D.B.
" - dumela1
I have a hoover vhd844db that has an intermittent error keep happening (E3). This is supposed to be...
(More)
I have a hoover vhd844db that has an intermittent error keep happening (E3). This is supposed to be a blockage or kinked outlet pipe or something, so I check the filter etc and it usually OK, It often does this a few times, then is OK for a while. Now its coming up with (E16) after I had to open the door mid cycle. Help me please, it's only 13 months old....
hoover wdm 130 motor wont spin fast , new bushes fitted did not fix problem all other cycles ok,...
(More)
hoover wdm 130 motor wont spin fast , new bushes fitted did not fix problem all other cycles ok, pump checked ok ,
My hoover 1600 washer is flashing stop, ready to start but the start button doesn't work when...
(More)
My hoover 1600 washer is flashing stop, ready to start but the start button doesn't work when pushed??????
