i have a technik tkl9260 and the drum is solid and will not spin. I have had a look at the rubber seal at the front of the machine and it appears to be dislodged at the top of the door closure area. Is it likely to be a simple job if I try and take out the rubber seal and then reinsert it or should I call someone in to repair it?? It is no longer under warranty.
My kitchenaid washing machine is spinning out of control , making noises and leaning toward the...
(More)
My kitchenaid washing machine is spinning out of control , making noises and leaning toward the front. Top loader. Any advise whta might cause this problem?
Top Load Washer starts agitating right away before water fills up to proper level when washer is...
(More)
Top Load Washer starts agitating right away before water fills up to proper level when washer is first started and also the water stays on during the spin cycle and the water doesn't stop running until the end of the cycle.
