Question about Olevia LT37HVS 37 in. LCD HDTV
My olevia tv
The tv was mounted on the wall and the picture is damaged what do i do. it has lines
I need to replace the screen on my 37 inch Olevia HDTV ...does anyone know about how much this will cost me? Also is there any way I can tell if it is replaceable or if other damage was done causing it to be a total loss? A flower arrangement was thrown, hitting the screen and cracking it.
Posted on Jan 18, 2008
    Genius:
  • 1,067 Answers
See if u can take it back or have it sevr is it under warenty sell it on ebay as broke list your issue on it get sum cash back
Posted on Jan 06, 2008
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Posted on Dec 17, 2009
Mounting tv on wall
You would need to get a flat panel wall mount. Since you are unsure on how to do this, I would strongly recommend hiring a professional or handy man with experience installing the mounts. Not installing the wall mount properly could cause the TV to fall and damage the set(warranty will not cover the damage) or cause bodily harm to somewhere.
Sep 03, 2012 | Scott LCT37SHA TV
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
I have a Vizio p42hd and it was wall mounted. Picture quit but when I removed it from the wall I get picture if I have the tv standing perfectly straight up and down if I lean it against the wall it goes...
The most likely explanation is that you have strained/damaged the connecting board or cable end at the rear, or less likely a cable has come loose inside. If it s getting it's feed from a cable at the rear hold the tv perfectly still and move ONLY the cables concerned one at a time. It may just need a new cable or plug if not... Try prodding / tapping around to see if you can localise it further. Either way you will probably need to dismantle if all connections are ok. I hope you didn't use screws that were too long when it was wall mounted as that may have damaged a circuit board or cable inside it
Jan 27, 2011 | Televison & Video
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Yes,i switch on my tv and the picture and sound are perfect for 2 minutes ,then the screen goes blank.The power light comes on but no sound and no picture.please advise ,thanks
It is totally internal problem. May be chip set issue..i suggest you to go call service technician.Don't take a risk, just give it in safe hands for repairing.
Jul 22, 2009 | Philips 42PFL3603D 42 in. LCD TV
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
May 15, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
130 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
