Question about Philips DVP3040 DVD Player
Sound dubbing seems off
I own a Phillips dvp3040 purchased a little over a year ago. During the first half of most movies the sound plays just fine but during the latter portion of some movies the sound dubbing is off with the sound lagging behind the picture
  • Anonymous Nov 26, 2008
    I have noticed this too. I found a workaround because I'm too lazy and cheap to buy a new DVD player. If you press 'Stop' once and then press play, the film will resume and the audio will be synced. You might have to do this again if the movie is longer than 2 hours.
    Scholar:
  • 48 Answers
Is this only on some movies? Look to see in your options is you have and decoder settings. What audio format do you prefer, DTS or Dolby?
Sometimes you may get a unit in which the decoder is faulty. If you have warranty options, first use those to get you a new unit.
Posted on Jan 06, 2008
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Philips hts3541 wont play new blu-ray movies
Sounds to me like a laser alignment issue, quickly get a support case going with the Manufacturer as most have a one year warranty whether or not you have a receipt.
Nov 02, 2013 | Televison & Video
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
Dec 29, 2007 | Panasonic DMR-E50 DVD Recorder
Multizoning my Phillips DVD player
The same thing happened to me. To fix, follow the instructions below. 1. Turn your machine on. 2 Press Setup on the remote. 3. Press Preference. 4. Type on remote 9653. The use arrow keys to select Region "0". 5. Then click OK and the machine should now recognise multiple region zone DVDs.
Sep 28, 2007 | Philips Televison & Video
No Sound During Movie Clip Playback
There won't be sound when you play it back on the camera, but when you upload it to your pc it will have sound. Also the sound quality is not good so anything above a normal talking voice sounds horrible.
May 07, 2007 | Vivitar ViviCam 5385 Digital Camera
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Philips DVP3040 DVD Player Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
