Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
When I starrt the cycle - any cycle - I'm getting an error - "Washing Er" then...
(More)
When I starrt the cycle - any cycle - I'm getting an error - "Washing Er" then "uo". As the water strats filling, it fills a few seconds, then something starts clicking (while it continues to fill) and the error comes up. Called frigidaire they said to shut breaker for 5 min. I shut breaker for 20 min but error still comes up. HELP!?
Dishwasher wil not run. The "Control Lock" light is on and will not go out by pressing...
(More)
Dishwasher wil not run. The "Control Lock" light is on and will not go out by pressing the "energy Saver" button or any other button.
