Question about Toshiba SD-3950 DVD Player
Works fine, then no picture.
We were watching a new DVD on our Toshiba 3950 thru to the end. We ejected it and put in a dfferent DVD. Now we have no picture and only sound - no matter what DVD is inserted. Cables all check fine.
  • 1 more comment
  • NewNickname Jan 07, 2008
    Actually - the fix turned out to be simple. My wife accidently pushed the "progressive" button on the remote in between the DVD's getting swapped, which must have put this into that mode, where no picture, but sound was getting thru. We fiddled with the remote and pressed the button again - now all is fine. Thanks for getting back to me though!
  • Anonymous Feb 05, 2008
    I had the same problem. My 2 yo son must've pushed the progressive button and no video. Pushing the progressive button again solved the problem. Thanks FixYa! (and Google)
  • Anonymous Nov 15, 2008
    Had the same problem. Same fix. Progressive button was pressed by my son as well. I LOVE the internet...
  • 1,074 Answers
Clean the lens of your dvd.if that does not work your lens must have gone bad have a tech look at your set for possible repairs.good luck
Posted on Jan 06, 2008
Purple and green color only
If you replace the video cable with a new one and it works, it's because the cable has a break in it.
If a replacement cable has the same problem, the break is inside of the DVD player and it will need to be serviced or replaced.
-=/ MLFnet /=-
Jan 10, 2011 | Toshiba SD-3950 DVD Player
I put a dvd into player and watched it then when i was finished and pressed eject, the dvd wont eject on laptop
Either go to my computer and right click on the drive then to eject or you can use a pin to insert in a tiny hole by the eject button on the drive itself.
Jan 09, 2011 | Toshiba Computers & Internet
No picture while watching DVD but sound works
make sure the dvd player is not in progressive scan mode
Apr 13, 2010 | Toshiba 14DLV75 14 in. TV/DVD Combo
Put in dvd and it spins and churns and then just says "loading error". Everything was fine a few days ago!
These units when the glass laser eye lens is dirty and needs to be cleaned with rubbing alcohol and a cotton swab, or the laser circuit or motor is faulty and needs to be replaced.
Oct 10, 2009 | Toshiba SD-3950 DVD Player
VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
System constantly re-booting
While this post is very late to answer this question, here is where I found a solution with the DVD still inside. When I used this solution, the whole system reset and worked.
"I had the exact same problem tonight. I put in a DVD and it locked my Toshiba RS-TX20 up. It simply wouldn't respond to anything but unplugging. Then it went into this infinite loop of trying to power up.
I finally got it to boot:
Hold the eject button on the unit continuously while it boots up (be patient!). It didn't open the tray until a couple minutes into the powering up process. After I took out the disc, it booted up normally at the next try.
I am guessing that there's a very small window during the booting process that the dvd drive isn't locked and you have to push the eject button in that small window to get the tray open. Since we don't know when the drive is unlocked, the best bet is to hold down the eject button continuously.
I hope this helps!"
Nov 25, 2006 | Toshiba RS-TX20 DVD Recorder
Toshiba SD-3950 DVD Player Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
