hi unplug pull out machine if drain hose is at bottom of machine get bucket put hose in to it water will flow out when full raise hose water will stop repeat untill empty if hose is not at bottom tilt machine so counter top holds it get pot what ever wil fit under the drain fliter unscrew slowly not all the way to let out water once pot is full tigheten repeat untill water is out then open fliter clean look in make sure notthing is wraped around impeller if so take apart and put back same way
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow...
(More)
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow changes to programs etc but as soon as start is selected it just beeps & continues flashing (start button- 5th led across)
The LED display disappears and the cycle stops. I have to press the green start/pause button to...
(More)
The LED display disappears and the cycle stops. I have to press the green start/pause button to restart the cycle.
i keep getting error messgae e20 when using dryer part of zanussi jetsystem turbodry 1200. it just...
(More)
i keep getting error messgae e20 when using dryer part of zanussi jetsystem turbodry 1200. it just beeps and stops drying
